Question about Health & Beauty
How do I change the time on the MK6MPJC controller?
How do I fix trouble code p1354 on a 2000 Toyota avalon?
P1354 Toyota Description
Variable Valve Timing (VVT) system controls the intake valve timing to proper timing in response to driving condition. The Engine Control Module (ECM) controls Oil Control Valve (OCV) to make the intake valve timing properly, and, oil pressure controlled with OCV is supplied to the VVT controller, and then, VVT controller changes relative position between the camshaft and the crankshaft.
Read more: http://engine-codes.com/p1354_toyota.html#ixzz3LEjKp1Z2
Dec 07, 2014 | Toyota Cars & Trucks
Tip
Change time/date on Partner ACS processors
<i><b>Partner ACS, any release</b></i><br><b>Changing the time on a Partner system must be done from extension # <b>10 </b>or <b>11</b>.</b><br><b>1. At station(Ext.10 or 11) press feature, 0, 0<br> 2. Press the left intercom 2 times<br> 3. Enter # 103<br> 4. Enter the correct time in 24 hr. format, for example:<br> * to set the time for 09:00 A.M., enter 0900<br> * to set the time for 04:45 P.M., enter 1645<br> 5. Press feature, 0, 0</b><br><a href="http://www.Telemanuals.com"></a>
on Jul 17, 2008 | Avaya Partner Control Units and Cards:...
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Feb 07, 2014 | Toshiba Computers & Internet
How can i reset oil change light of an international maxxforce truck 2012
1. if not already done, set the parking brake.
2. turn the ignition switch to the ON position.
3. turn cruise control on
4. turn cruise control off
5. turn cruise control on
6. very rapidly push the RESUME button four times and then hold for four seconds on the fifth time.
7. oil change light should clear.
8. the time the cruise control is turned on for the second time to the time the fifth activation of the resume button is held down must be within 6-7 seconds, if not you must repeat the process.
Mar 14, 2013 | Cars & Trucks
I can not control the air position .it is always at my feet ..and also i just change the thermostat and still some time i have no heat... im thinking its the control unit i have to change .
i think the heat control in this is electric and a little motor moves the damper open and closed you can check the two motors but its probable the heat control unit check and see if you have power going to heat unit
Jan 10, 2013 | 2001 Dodge Ram 1500 Truck 2WD
What's this oil control valve circuit bank 2 mean?
The oil control valve is used by the computer to change valve timing.
There is a problem in that the computer can not control the valve to change valve timing. Could be the control valve, sludge in the engine, or a wiring problem between the control valve and the computer.
Dec 15, 2012 | 2001 Toyota Sienna
I have a 2003 a4/b6 1.8 turbo and the engine light is on. The DTC codes says random misfire, misfire on cylinder #2 and #3 also, Oxygen (Lambda) Sensor Regulation: Bank 1: System too Lean : P1111. Any...
If you can supply me with all the codes your vehicle is showing, I can assist you. As far as the P1111 DTC goes I have listed the info below with some possible solutions.
P1111- Intake Valve Timing Control Solenoid Valve Circuit Bank 1
Intake valve timing control solenoid valve is activated by ON/OFF pulse duty (ratio) signals from the ECM. The intake valve timing control solenoid valve changes the oil amount and direction of flow through intake valve timing control unit or stops oil flow. The longer pulse width advances valve angle. The shorter pulse width retards valve angle. When ON and OFF pulse widths become equal, the solenoid valve stops oil pressure flow to fix the intake valve angle at the control position. The code is triggered when an improper voltage is sent to the ECM through intake valve timing control solenoid valve. Since the Intake valve timing control solenoid valve uses oil flow to control timing, dirty oil can cause the valve to stuck open or close. Before replacing the valve, change engine oil and filter and reset engine code.
Possible Causes:
- Intake valve timing control solenoid valve bank 1 circuit is open or shorted.
- Intake valve timing control solenoid valve bank 1 circuit connectors
- Dirty Oil
Possible Solutions:
- Change Oil
- Replace Intake valve timing control solenoid valve
Jan 20, 2011 | 2003 Audi A4 Cabriolet
My Dual Shock 3 controller won't connect with the system
go into you accesory settings and change the controllers designation,change it to number 1, it will get changed from time to time cuz of drums or guitars being designated as no 1(especially mic's).
Nov 20, 2009 | Sony Dual Shock 3 Controller for...
System date and time does not change on my laptop
What do you mean it "does not change"? Have you tried to change them using the Control Panel applet, or by clicking on the time in the taskbar and trying to change it there? Or, do you mean the date and time is not incrementing at all while watching the time?
Mar 23, 2008 | Computers & Internet
Health & Beauty Logo
47 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
