Question about Drills
My bosch 11264evs sds drill is still working but the electrical current is flowing though the tool so that the bit will arc when touching anything metal, like concrete support wire or rebar in a wall.
Two years old and used regularly, but it is well treated and cared for, but this problem just started happening as we were chipping out some concrete around a tub drain.
    Genius:
  • 2,494 Answers
Take it to an electrical place to be checked out .
Posted on Nov 09, 2014
5 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: Tool bogs down while drilling holes in concrete-as though it's binding up inside.
Depends what damage has been done to the motor. If the tool is still running but sparking you need to check what sort of sparks they are. Short fat blue sparks only going halfway round the commutator (brush end of motor/armature) then it is 90% probable that just your field coil assy is blown. If it is thinner, whitersparks going all the way around then it is the armature and possibly the field aswell. Another way to check is to remove the brushes via the covers on either side at teh bottom of the motor and check the contacting surface. If it is fairly shiney and polishe then there is little sparking and hopefully no cause for concern. If one or both is pitted and dull it has been sparking and burning. If one is shorter and darker than teh otehr this indicates a problem with the field coil. It isn't a massivly hard job to change the motor parts. If you need more advice let me know.
Posted on Oct 25, 2008
pranaclimbin
  • 50 Answers
SOURCE: BOSCH HC8531 CORE BIT
no u dont need water when drilling into concrete with a concrete bit.
Posted on Dec 05, 2008
  • 1388 Answers
SOURCE: BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Posted on Dec 16, 2008
rowdy45176
  • 2176 Answers
SOURCE: sds drill popping sound as though something has
It is if you continue to use it. The best way to check is unplug the tool and find where the brushes are and check their condition and the condition of the brush spring for burning. when you have them out rotate the tool by hand and look into the brush tube for discoloration of the surface the brushes ride on (commutator) if they are raised or badly discolored then you might have a serious problem with the electrical portion. If the brushes are worn shorter than 1/4" I would replace them Let me know the brand and model and I will try and find a schematic for you to make it easier.
Posted on Apr 21, 2011
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Drill bit rotation stops
www.powertools-aftersalesservice.com this site allows you to input the model number in the trade name box or if you look on your tool you will see a 10 character code quite often starting with a '0' enter this number in the part number box. This will then display your exact model variation, voltage etc. (the former search will bring up a list of possible models, voltages and countries). From the parts break down you will see there is a clutch fitted. Testing of clutches is not easy and many makes can not be adjusted. I have seen on SDS drills the guide lugs in the tool holder have sheared/Worn away and the drill bit can be turned freely if the steel balls are removed from the chuck. On a max there are more lugs but I don't suppose it is unheard of these al wearing away. If it is a clutch problem you will hear the drive slipping. If it is the latter the drill will sound normal. All that said It could even be gear teeth that have broken and so not meshing in the rotation mode. Only stripping the tool will identify the fault.
Mar 01, 2014 | Bosch 11264EVS 158 SDSMax Combination...
I have a bosch 11264EVS hammer drill that just stopped working. I checked the brushes and have continuity to the rotor. Is there somethingelse I need to check/replace before I hunt sown a service center?
Did you have continuity from one brush to the other? Some Bosch tools use "pop off" type of brushes. When they get worn down a spring loaded center pops out and keeps you from damaging the armature. If they are fine check cord continuity. If the cord is fine it is most likely the switch. You can test the field for continuity also but those rarely ever fail. Here is the parts diagram.
Bosch 11264EVS diagram
Aug 24, 2012 | Bosch 11264EVS 158 SDSMax Combination...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
Need sds to hex shank adapter. Where to buy?
If you have SDS-Max, ereplacementparts.com has one made by Bosch that'll go from SDS-Max to 3/4" Hex:
http://www.ereplacementparts.com/sds-max34-hex-rotary-hammer-adapter-p-165057.html
I'm having a hard time finding one that'll do SDS-Plus, though.
Aug 19, 2009 | Bosch Drills
Drilling a 1 3/4 x24" deep hole in rock . i wore out a dewalt rock carbide dw5830 after just two holes. what should i be using. thank you
I'm a fan of bosch bits and equipment! but try slowing your drill down a touch and even use a little water this will help the life of the bit!
Jun 06, 2009 | Black & Decker 3/4x6" Rock Carbide Sds...
I cannot get the drill bit's to stay in my dewalt D25003 drill, do I need special bits or an adapter?
Are you using a SDS bit in this tool? If so you might have a problem with the bit lock mechanism, if not you do need the special SDS bits that will lock into this tool. Let me know
Apr 12, 2009 | Dewalt Drills
Bosch 11222EVSG hammer drill not turning
Couple things to look at, First is the selector in the hammer/rotation mode? Without a bit in it does the collar turn when in the rotation mode. Are you using the right bits for this tool. If yes to all of these I would look down the spindle and make sure that the pawl are in place (they lock to the bit for rotation) Let me know and we will dig deeper.
Mar 06, 2009 | Bosch 11222EVSG 1 1/8 Inch Grounded Sds...
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drills Logo
476 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
