Question about Crock Pots & Slow Cookers
I have the Black and Decker 7-Quart digital slow cooker and it does not seem to be working properly. Upon reading and following the instructions, everything is seemingly fine and cooking for about 5 m
I have the Black and Decker 7-Quart digital slow cooker and it does not seem to be working properly. Upon reading and following the instructions, everything is seemingly fine and cooking for about 5 minutes, but then the unit starts beeping at me and the display shows an "E3" on it and ceases to function. Am I doing something wrong or is this a mechanical fault?
4 Suggested Answers
  • 1739 Answers
SOURCE: I need an instruction Manual for my Wolfgang Puck
Wolfgang Puck Instruction Manuals are available here:
http://www.wpcookware.com/manuals.asp
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Posted on Apr 01, 2011
mizrach612
  • 102 Answers
SOURCE: can I get an insert for my GE 6.5 qt digital slow cooker
Even if you can't find an "insert" from Walmart or GE, for that specific cooker, you can use inserts from OTHER cookers that will fit and accomplish what you want. You'll have find one that fits YOUR cooker though. just take the measurements of the diameter of your cooker, go to a store that sells "inserts", and make sure any kind of insert you want is a smaller diameter than your cooker.
Posted on Sep 24, 2012
SOURCE: I lost the Manuel and iv looked online and I can't
right there in PDF :) http://pdfstream.manualsonline.com/2/26d5b806-c055-4510-a7eb-5af718227a4b.pdf
Posted on Jun 18, 2014
What is code e3
No one, including the manufacturer seems to be able to answer for that error code. Sorry.
Mar 02, 2016 | Crock Pots & Slow Cookers
What does e3 mean on the power pressure cooker xl model ppc770/PPC770-1?
No one, including the manufacturer seems to be able to answer that question.
Oct 25, 2015 | Crock Pots & Slow Cookers
Crock pot will not stay on..What is Wrong?
Could have a fault. I would get it replaced as you have had it less than a month.
Jan 08, 2015 | Crock Pots & Slow Cookers
Why is all lights flashing on display but wont respond by pushing buttons.. keeps beeping??
Unplug it, wait 15min replug and start again..the lights should indicate the high and low temp long or short time , and then of course warmer ..sometime high and low as well
Good luck
Aug 14, 2014 | Crock Pots & Slow Cookers
Keeps shutting of with red f4
e-mail the company or the manufactor, maybe you might be able to have a new one.
Mar 08, 2013 | Crock Pots & Slow Cookers
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Crock Pots & Slow Cookers Logo
81 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
