Question about Ovens
I have a CDA oven model SC510SS THAT WONT GO ABOVE 175C I changed element at the top of the oven, and problem is still there. Seal is good, could it be thermostat, and if so how do I check
CDA SC510 SS FAILING TO HEAT ABOVE 175C, replaced element and seals are good, could it be thermostat that clips onto the element base, if so how do I check
  • 6 Answers
SOURCE: Thermostat or Heating Element?
Check out our element replacement guide at: http://www.ransomspares.co.uk/fan_element_article.html
Posted on Feb 28, 2007
  • 1462 Answers
SOURCE: NEFF Oven Model B1430NOGB/02 Oven Temp not heating above @50 degrees
probably the element. to save wasting money, check continuity with a multimeter
Posted on Jun 25, 2008
  • 250 Answers
SOURCE: Stoves 900GDO Bottom oven door seal
The handbook tells you how to take the door off. If you can do this, do so and then clean/spray all the door hinge mechanisms with WD40. Remove the surplus with kitchen towel and replace the door. Operate the door a number of times to see if this has cleared the problem. (Over time the hinges seize up and the WD 40 normally eases this situation).
(Don't be confused with the air flow coming out of the oven from the cooling fan as this also runs along the top edge of the door).
Posted on Apr 04, 2009
MAD ICE
  • 52 Answers
SOURCE: Jenn-Air double oven door seal W241
it is very simple if you look at the back of the oven there is part number and serial number yet there is the model number and you can search it on the internet i i changed mind simple but i change the window of the oven it had 4 screws and i took it out and in put in withen 20 mins . without the manual how ever if you still think cant do it look a the model of it and see what does it need to be removed you are smart good thinking changing by your self then sending to repaire and yet not alot of people will do what you do..
Posted on Apr 21, 2009
SOURCE: hello we have a fisher and paykel classic stove
c55aadb.jpg Isolate power from device, remove screws to free back panel.
769e143.jpg Loosen strainer for oven liner on left and right sides and remove clip to allow oven liner to slip forward.
e87a68d.jpg Remove screw on front central upper clip.
42f6dbf.jpg From front, move oven liner forward a few millimetres to release gasket. Here you see the strainer at the rear has moved forwards a few millimeters.
e8ea79b.jpg Remove the old perished seal.
f86ae37.jpg The new seal/gasket part number 573263 is installed. Reverse dismantling procedure to complete reassembly.
Posted on Aug 28, 2010
My whirlpool oven (AXP206/IX) is not reaching the temperature I want, 200c. It will only go to about 175c. Any ideas please?
are all the elements heating (glowing ) when on , ifnot then the ones that are not possibly need replaced .
Oct 28, 2015 | Whirlpool Ovens
How do I replace the bottom oven element in a CDA CD 907 double oven
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
May 10, 2011 | Ovens
The oven wont turn on,fan works but heat wont come on
Most likely you have a faulty fan element- this is a round element that goes around the fan at the back. To check- Disconnect from power(easiest way is to switch off oven at fuse board). Remove rear panel inside oven (held on by screws), and visually check element- often you will see a blow mark on the element. Element is easily changed, although sometimes requires oven to be removed to access element wires from the back. Proceed if you are a confident DIYer, otherwise call a local service agent. Elements are readily available for $75-$125 depending on the retailer. Can give further advice if you provide a model number. Good luck!!
Mar 10, 2010 | Fisher and Paykel Ovens
Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Jan 04, 2010 | Ariston Technologies Ovens
My CDA fan oven will not get hot
Ok , classic example of a fan oven element blowing, take the cover off inside the cooker held on by 4 screws so you can see the round element, you should be able to see where its blown a big hole.
replace element
( make the cooker is turned off of course)
Sep 18, 2009 | Ovens
Bottom element broken
Mark,
There should be an element on the top, used for broiling, and then one on the bottom. If you look inside the oven carefully at this element and the top as well, should should be able to see a small blown out spot, or even a break.
If you do, turn off the range at the breaker box, and two screws should take it out. Take that and the model number of your stove to an appliance parts dealer. It won't be very expensive, although he may have to order it in for you.
If the above is not the case please write back.
Sirwriter
May 16, 2009 | Electrolux Ovens
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
CDA double electric double oven user manual model snr 99
I have had installed a CDA electric double oven. Its been in approximately 3 years but my main oven looks like the thermostqt has gone. The on/off lightdoes not go off. The Model No. is CDA 708 I can't find the Serial No. Can it be renewed I live in Nottingham.
My email address is - beryl.donohoe@tiscali.co.uk
Feb 27, 2008 | Ovens
Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Sep 27, 2006 | Whirlpool GBS277PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
