Question about Sewing Machines
Get the blade down to cutting postion when it stuck up ward
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
I assume this is a serger. You kinda need to say what model.
Posted on Nov 26, 2014
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
Kenmore 15212 needle is stuck in down postion and hand wheel will not turn?
Loosen the needle screw and try to remove the bobbin case from the machine. Once things are loose, the needle should be freed.
Jul 17, 2017 | Kenmore Sewing Machines
Can anyone tell me what size table saw a Montgomery Ward Powr Kraft, it looks like model tpf34867, would be? Maybe 8, 9, pr 10 inch.
Ask around your friends and associates for a used 10" blade and see if it will fit.
Back when those were made, most all were 10".
The saws using smaller blades of 8 or 9 are much more recently produced.
God bless your efforts
Jun 26, 2017 | Montgomery Ward Sewing Machines
I have a Montgomery Ward model 1934 sewing machine. The reverse button has no tension and the machine is stuck in reverse stitch mode. Can this be repaired?
You may want to take it for service. Could be the machine has seized with the reverse button stuck. May need to be disassembled.
Dec 06, 2016 | Montgomery Ward Sewing Machines
Do I have to have the cutting blades on the machine to serge material? Also, what's rolled hem and whats overlock?
No you do not need the cutting blade to serge but you shouldn't have to remove the blade it you should be able to push the knob at base of blade inward or pull it outward to turn blade downward out of the way.
TUTORIAL - How to do a rolled hem on a serger - StitchCraft
http://stitchcraftonline.com/blog/?p=42 - 71k - similar pages Aug 5, 2009 ... One of my favorite uses for my serger is to do rolled hems. A rolled hem is were the machine folds the fabric under a tiny bit and then stitches it.
Jan 05, 2015 | Sewing Machines
Can I stop my semco 750 overlocker cutting the material when I'm sewing
You should be able to disengage the cutting blade. Probably a button that you push in then rotate anti clockwise, this will turn the blade down under the machine therefore not cutting the fabric.
Good luck
Oct 04, 2014 | Sewing Machines
I have a Babylock 5260 serger and have changed the blades before but this time when I changed them I can't get them to align correctly. the top blade comes down and hits the bottom blade. I cant figure out...
First make sure that both blades have no burrs on the them from hitting pins. Then set the lower blade so that the cutting surface is flush with the surface of the needle plate. Then adjust the upper blade so that when it comes down to it's lowest position on the downward stroke of the cutter arm, that the cutting edge comes down past the lower blade at least 1MM. That will ensure a full cut of the blades.
Apr 26, 2011 | Sewing Machines
Blades will not cut
A few things to check here; 1. do the blades cross over each other when the upper blade is fully down - if not make sure lower blade is flush with top of needle plate and then loosen upper blade and set it so that the blades cross over for the full length of the blade when down. 2. is there any lint or thread caught between the blades - push the upper blade to the right and look between the blades and remove any material caught between them. 3. are the blades damaged - blades can become chipped from sewing over pins etc and also become dull after considerable use (replace if damaged).
Nov 04, 2009 | Brother Lay-In Thread Serger Mechanical...
Serger blades do not cut.
For now, it works only satisfactorily:
I applied alcohol to further clean both blades,
dried and then oiled them. There seemed to be a slight gap between blades;
the fabric was dragged into the gap instead of being cut.
Jan 10, 2009 | Elna 1010
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
