Fan wont change from low to high on GE heater/ac unit
GE model AZ38H15DABM1 heats and cools great but the fan doesn't blow as hard as it used to. To get the air distributed. I Checked the DIP switches but still nothing.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Clean blower and coils , check out fan motor and fan capacitor .
Posted on Nov 30, 2014
  • 54 Answers
SOURCE: Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Posted on Jun 08, 2008
james3751
  • 614 Answers
SOURCE: This is a heating and
You have a bad board or bad switch. I would say board. You can have service tech check this out. There is only so far you can go without knowledge of Controls ad electricity. Russ
Posted on Jul 22, 2009
keith91gmc
  • 52 Answers
SOURCE: My low cool air works, but when I put it on high
most likely the control switch is bad or burnt wire terminal
Posted on Aug 29, 2009
heatman101
  • 43501 Answers
SOURCE: The heat and fan are
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Mar 20, 2011
SOURCE: i have a ''GE"heat &
Look at the wires that go to the compressor and make sure they are not burned off. Inspect the capacitor tops for swelling and loose or burnt wiring. Also check the connections coming from the controls. May have a wiring problem or even a bad compressor. How old is the unit?
Posted on May 17, 2011
Fan speed wont change speeds on heat or cold cycles
Sounds like the Blower Motor Resistor. The range from 10 to 75 dollars depending on what kind of vehicle. Pretty easy to change.
Blower Motor Resistor Repair Heater Fan Speed Control Chevy Blazer GMC...
Nov 09, 2014 | Cars & Trucks
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
Dec 09, 2010 | Fujitsu Heating & Cooling
My heater fan wont turn on in auto mode but will in manual
Well you have a good transformer and the fuse is not blown. So I would look for the most obvious thing which is the relay. Why the relay? Well most units do double duty as air conditioner and heater. AC and heat require different fan speeds. The relay shifts the fan from low to high for ac. The fan runs on low for heat. In rare instances it could be a bad wall thermostat but most times not. You know the fan is good because you can get it to come on manually.
Some Repair Photos
Dec 24, 2009 | Heating & Cooling
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Ice build up out side hitting fan
pop out drain plug heat up pan with heat gun to melt ice
Nov 24, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
