Question about Acer Aspire 5349-2592 Laptop Celeron 1.5ghz, 320gb, 2048mb, Dvdrw, Wi
My Acer Aspire 5349-2592 network adapter keeps having to be reset by troubleshooting, but it doesn't always solve the problem. Is there a driver I can replace it with?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 884 Answers
Hi there
I assume that you are using the ethernet connection and have proved that there are no problems with the cable, wall socket, router, network generally,etc.
If so the first thing I would do is to go to the link below, select your product from the lists given and check the driver you have installed is the correct one for your operating system, as there is only one listed for your machine. The simplest way may be to simply download this driver and install it to see if this cures your problem.
Drivers and Manuals
Alternatively if you are using a wireless access point you will need to check which wireless adaptor you have and then down load the appropriate driver and install it.
If these both fail to correct the problem, and all the rest of the network components are fine, you may be looking at a gradual deterioration of the LAN hardware, in whci case you should consider repair, or just to check, obtain a USB wireless LAN adaptor and driver and try that. They are relatively cheap, and if the problems continue even after that then the cause must be outside of your laptop and its hardware.
Hope this helps
Cheers
Posted on Nov 09, 2014
I've got an Acer aspire one d225 ,& it has wifi problem
Turn on your computer and locate the Wi-Fi icon. This could be located on the upper row on a laptop it will have the radiation look ((())) Make sure its pressed on. The internet connection is located in the system tray in the bottom-right corner of the screen. The icon looks like a series of rectangles that increase in from left to right. Right-click the Wi-Fi icon and select "Connect to a network." You will see a list of available wireless networks. Wireless Acer laptop can be a massive boon to your productivity when it is working properly and a massive headache when it is not. When your laptop card begins to exhibit undesirable symptoms, such as signal dropping, you can avoid a hefty repair bill by performing at-home troubleshooting. The best solution is to merely reinstall the software driver, which refers to the program that the operating system uses to speak the wireless card's language.
Open your operating manual and look up the model name and number for your laptop. Navigate to the Acer Support web page (see Below) and click on the "Downloads" link. http://support.acer.com/ Input the model number of your laptop, click on the "Search" button, download the wireless driver file for your laptop model and save the file to your desktop. Open the "Start" menu, click on "Control Panel" and open "Device Manager." Open the "Network Adapters" menu, double-click on your wireless card, select the "Drivers" tab, click on the "Update Drivers" button and choose the desktop as the location to search for new drivers. Click "Next" to reinstall the driver, fixing your wireless woes.
Feb 24, 2013 | Acer Aspire One D255 Netbook
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
My acer aspire 4741G , doesn't start up, it always goes to start-up repair, but it takes long for that process, then when it finaly finishes it still goes back to start-up repair, it it still...
Older Acer laptops use alt-F10. Newer Acer laptops use F11 to reset to factory operating system by hidden partition faster than restore cd..
Mar 04, 2012 | Acer Computers & Internet
How to format a notebook that doesn't have a cd drive
You'll have to buy a external Drive. Then you can boot using a OS CD or DVD
That's it Pretty Much
Good Luck
Oct 20, 2011 | Acer Aspire One PC Notebook
My netbook won't let me connect to a wireless network, it tells me to reset my wireless adapters. I don't know how
To reset the wireless adapter, click "Start", click "Control Panel", and go to "Network Connections" (XP) or "Network and Sharing Center" (Vista or 7), Vista and 7 will have to click "Network Adapters" from there. This should bring up a screen with all available network adapters. Right click the one that likely has the word "wireless" or a "g" "b" or "n" in the name, and click Repair or Reset.
Aug 24, 2011 | Acer Aspire One D255-1625
Acer aspire 7736z on button flashing can not start
!- Disconnect from Power Adapter and remove battery
2- Press Power button for 5 seconds
3- Put the battery back and start the laptop
if this doesn't work check memory and/or mainboard, or bring it to a certified troubleshooter.
good luck!
Jun 02, 2011 | Acer Computers & Internet
Does the acer aspire z5700 desktop have a built in wifi router or do i need to purchase and set up a router to enable home sharing network?
While it doesn't have a built-in router, it DOES have a wireless adapter built in. So if you were to purchase your own router (or rent one from your ISP), the computer would work fine with it.
More details on your computer here:
http://reviews.cnet.com/desktops/acer-aspire-z5700-u2102/4507-3118_7-34132723.html?tag=doormat;rnav
May 02, 2011 | Computers & Internet
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
Open Questions:
can you please help ms drunel broussard who just received custody of 2 of her abused grandchildren in nov 2017 have a great xmas not having a home with furnishings..she no longer have stable housing ms drunels daughter and boyfriend had been abusing her children..shes a great person with such agood heart and shes struggling to keep the kids..while in moms care the kids was sleeping on the ..have very min clothing..ms drunel took her car notes monies to get the kids basic clothing and hygiene needs..shes help so many7 ppl and always been an strong person..not knowing where they would lay their heads at..i watch her go and visit ,pray for ppl in the hospital..when you ask herhow is things going shell say all will be well..but today i seen her breakdown and crying..letting the kids know she might have to let them go to foster care because she cant provide them with a stable place..to know her is to truly love her..and to see her not be able to care for them the way she cared for hewr children and other ppl children is taking a toll on her.but she keeps smiling..she really need help and an agency in jax fl where she lives told her to give them up or go to a shelter...she replied ok ..and left..doors is not opening and due to the NATURE OF THE abuse..and physical abuse these babies been through she said no..they have nothing i mean nothing for xmas...less alone shes facing losing her means of transportation to get them to and from school...counseling ...and dr.appt...PLEASE PLEASE I BEG OF YOU HELP THIS FAMILY...THANK YOU FOR YOUR TIME
Dec 14, 2017 | The Computers & Internet
See all Acer Aspire 5349-2592 Laptop Celeron 1.5ghz, Questions
Acer Aspire 5349-2592 Laptop Celeron 1.5ghz, 320gb, 2048mb, Dvdrw, Wi Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
