Question about Protron Televison & Video
What are instructions for Split-screen TV? Used before, forgot.
We know split-screen is know longer widely used, but would like to use again. Please help. Have wiring.
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
You are referring to a picture-in-picture function on hour TV. It is usually done by a button on your remote control marked PIP - picture-in-picture. If your TV doesn't have this function you can get it by using your SET-TOP BOX, which supplied by your TV cable company. All modern remote controls fro those boxes have that ability. In this case you will be able to watch two channels at the same time, switching them around and control them the way you want.
Posted on Nov 10, 2014
retrohack
  • 27 Answers
SOURCE: Tv won't turn on
The problem is the electrolytic caps in the switch mode power supply. They are located on the output side of the supply board. You can tell which ones are bad by the "bulge" on the top of each cap. All need to be replaced..
Posted on Aug 30, 2007
SOURCE: EMERSON SCREEN SPLIT
Rosey074, looks like the number for Emerson is: 1-800-256-2487.
Good luck.
Posted on Dec 11, 2007
  • 1779 Answers
SOURCE: VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Posted on Feb 18, 2009
  • 12 Answers
SOURCE: cannot disable split screen (DIST dynamic gamma)
the way i solved it is by holding down the menu and the volume(-) and the disabling the dis. That worked for me so you should try it.
Posted on Jun 21, 2009
  • 5 Answers
SOURCE: Black line in middle of 42'' plasma screen
Its most likely going to be a D board or a C2 board, I had vertical lines on mine got the service manual and it breaks the screen down into squares, well I had a problem where the lines were all over, stuck pixels ect, replaced the D board and all is well, fix was quoted at 300 by a local shop friend after I told him my problem so it would be worth the tech to fix it. If you could do it yourself (it is pretty simple) the boards are cheap on ebay.
Posted on Oct 01, 2009
We have xbox360 it's hooked up to sansui sledvd244 how do i get split screen so there can 2 players please help
Minecraft Xbox 360 is a multiplayer game by default. Players can join online or locally via connected controllers. Split screen is a way to play multiplayer on the same console. To play split screen, the Xbox must be outputting a resolution of 720p or higher.
you must have an HD TV for split screen. Connect Xbox to tv with an HDMI cable. Start mine craft when you've logged on with your first controller enter your desired world then pause the game. Turn on and sync your other controllers if they haven't been connected before.Log in those controllers and press Resume Game.
  • Your television screen should be split into two or four parts depending on how many controllers are connected.
Dec 06, 2014 | Sansui Televison & Video
Tip
How to reset the lamp timer for Panasonic DLP TVs.
When you replace the lamp on a Panasonic DLP or LCD TV you will need to reset the lamp timer to zero for the TV to reset the lamp timer and extinguish the change lamp indicator.
There are two methods used depending on which model TV you have. The older units use the first method and newer units use the second method. You can tell which method you need to use by whether you have a PIP and/or SPLIT button on your remote. If you have them use the first method, if you don't use the second method.
Method number 1 (for older units):
Follow the procedure below. You use either PIP or SPLIT button depending on whether your remote has SPLIT or not. Some do not.
Perform lamp timer reset only when the lamp has been replaced. The idea is to know when to replace the lamp before the end of it's life when it could explode or short out causing a hazadous condition. If you reset the lamp circuit at any other time the replace lamp warning will not come on at the recommended interval.
Be sure the power cord is plugged into a properly grounded wall outlet.
Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the
PIP or SPLIT button on the remote control at same time for more than 5 seconds.
If your remote does not have a split button you use PIP, if it has a split button, you would use SPLIT.
When reset procedure is complete, the screen on the TV will indicate that the lamp has been reset. When lamp time reset is finished, the LAMP indicator goes out.
Method number 2 (for newer units):
Press volume down on the TV and the zero button on the remote at the same time for longer than 5 seconds and it will reset the lamp to zero.
These procedures should reset your lamp timer and you will be good until the current lamp fails or the change lamp indicator illuminates again signalling that it is time to replace the lamp. Three to six years on average depending on how much you run the unit per day. Do not ignore the indicator. Change the lamp immediately to avoid further damage and expense or worse.
Thanks for using FixYa and for the great rating.
hardrocko
on Apr 11, 2010 | Televison & Video
Fix split screen
There is no split screen option in a Comcast box. If your TV has a duel tuner you can get 2 boxes one for each tuner and still use that option in your TV. If you have a split screen on your TV and one is snow then you will need use your TV remote it came with to exit out of it.
Jan 25, 2013 | Comcast XFINITY
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
I have recorded a TV programme to the Hard Drive. However - I started recording manually and forgot to stop recording. So I have a recording 30 hours long! I want to copy the first 90 minutes to a DVD....
I used the edit function. I fast forwarded to the end of the section I wanted to record. I then stop the fast forward and used the split function. This split the original recording into two parts - the first 1hr 38min which I wanted to keep and the rest. It saved as two files and I was able to copy the first part to DVD and discard the rest.
Duncan
Dec 13, 2009 | Lite On LVW-5006 DVD Recorder
SPLIT SCREEN ON 50'' PLASMA
If you talking about on one screen, you cant. BUT you can buy a TV card for your computer so that it will have a built in TV. so you can theoretically have split screen TV and computer. But what your thinking off only works on 2 or more player games consoles
May 04, 2009 | Samsung PS50A457 50 in. Plasma TV
Bad Picture
When you say messed up do you mean the convergence is out? please explain a little more detail as to what you are seeing. Also when its messed up if you press the menu button on the remote does the menu look good?
Tim
Sep 10, 2008 | Toshiba 50H81 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
The split screen shadow remains on my 52SWX10B projection TV
Unfortunately, this sounds like the transition between the split screens is now burned into the phosphor of the CRT's and is permanent, unless the CRT's are replaced which would cost as much as a new TV.
May 04, 2007 | Hitachi 61SWX10B 61" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
