How to turn my TV back on?
I have a Digistar 40 inch LCD TV that i moved to a different room. When i plugged it in a day later, all i got is a flashing blue power light near the remote sensor. Pushing the power button again does nothing...unplugging the TV and plugging it back in does nothing either...The tv worked great prior to the move...what can i do??
    Problem Solver:
  • 11 Answers
Are you sure the panel of LCD is not damaged?
Posted on Nov 10, 2014
dodgecharger
  • 254 Answers
SOURCE: LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Posted on Nov 28, 2007
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
Hi i have the samesung ln26b360 lcd tv and for some reason when i went off to college like the 3rd day i had my new tv i had to unplus it to move it to the other side of the room well i moved it plugged it...
The tv power supply board is likely the problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 30, 2010 | Samsung LN26B360 26 in. LCD TV
I have a Sony Bravia LCD, while cleaing the room water goes in the LCD and now when ever i turn on, its stay on for 5 second and then goes to Standby and red light blink on the panel.
Tries tv unplug,replug tv back like about an hour later.The tv now should be resetting back to the factory setting.The tv should work now.But,if the tv still have same problems,the power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Digistar TV
Sorry, I am not famillar with your model, however most flat panel problems with start up can be traced to the power supply as the capacitors can fail due to the high operating temperatures. An electrical surge can also come in through the Cable and or antenna connection as well.
Jun 16, 2008 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
