Question about Toys
How to install the battery into leapfrog reader juniorr
    New Friend:
  • 23 Answers
How to add a leapreader book to a leapreader
you will need to download the LeapReader software from the LeapFrog web site
www.leapfrog.com
Install following the wizard
once installed on the righ there will be a link to download and sync the new software for your books
i hope that this helps?
Regards
May 06, 2014 | Toys
Tag reader won't turn on
mine won't either. do you have tag reader(takes batteries) or tag read and write(battery included)?
Dec 26, 2013 | LeapFrog Tag Reading System
I installed my leapfrog connect for my Tag reader. It says to plug in the Tag with the USB cable to the computer ( which i did) and turned it on. For some reason its not picking up so i cant go to the...
it depends on what Operating system your using, if xp then goto devices in the control panel and click on detect new devices, also check there if the usb drivers are installed, sometimes you have to install the software before plugin it in. if it's win7 then again click on devices and also check my computer when the usb is connected, and again install the software before plugin it in. best regards.
Oct 30, 2013 | LeapFrog Tag Reading System
Tag will not update
try downloading it on another system and transfer it to yours.
Aug 11, 2012 | LeapFrog Tag Reading System
Having and issue with the audio download on the Leapfrog Tag system. I have Leapfrog Connect installed on my Mac. Audio for books previously downloaded and newly downloaded are not able to be put on pen. I...
Just got this from LeapFrog. Worked for me, although it toook a couple of attempts.
For Macs:
Please try downloading and running this tool and connect the Tag Reader when prompted:
http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
For Windows machines:
1. Close the LeapFrog Connect application.
2. Double-click on this link http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe then click "Run."
3. Click "Unzip" to extract the files.
(You will be asked for a location to save the files. Save them to your Desktop or to another folder that you can easily find.)
4. After the files are extracted, find the "LeapFrogTagFixTool" folder on your Desktop (or where you saved the extracted files).
5. Open the folder and double-click the "TagFixTool.exe" file to open the LeapFrog Tag Repair Utility program.
6. Connect your Tag Reader to the computer. (Make sure your toy is powered on.)
7. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
8. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Jul 26, 2012 | Toys
When i turn on my son s tag reader it makes this loud buzzing noise and it turn off whats going on. i just replaced the batteries.
Make sure that the batteries are installed in the correct orientation (+/- polarity). This is the same thing that happens to my units. Also make sure the cartridge contacts are clean, and the cart is properly installed.
May 02, 2011 | LeapFrog Tag Reading System
The batteries in my daughters leapfrog Tag only last for a very short time...any ideas?
It might be the batteries or the brand of batteries. My son has had the tag reader for over a year now and we seldom change the batteries. Leapfrog may be against it, but we use rechargable enegerizer batteries. I can count on 1 hand how many times I've changed the batteries in the last 18 months.
Dec 27, 2010 | LeapFrog Tag Reading System
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
Silent reader
Yes, allow me to clarify......
It has worked for 1 year. We have already loaded it with the books and we've installed the software for it, but now all of the sudden, it won't sound unless it's through the headphones.
Jan 08, 2010 | LeapFrog Tag Reading System
Toys Logo
61 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
