My white Westinghouse washer model wwac14m3hekw doesn't rinse!
2 Suggested Answers
  • 6277 Answers
SOURCE: how do u replace broken
If yours is a 'standard' front loader (you do not say the actual model number) the belt should be easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 15, 2011
I have a Westinghouse LT8195 washing machine,error code is coming up SP ? Do know what this is ? Please help
I think you may have used the wrong kind of detergent or too much.your washer is most likely over SUDs.If you don't use he High Efficiency detergent this will happen. There is a he swirl on the container.shut down you washer for a half hour let it settle. Clear the drain as best you can from suds. if your model has a no spin or low spin use your rinse cycle.you may have to do this again if suds are to thick. Westinghouse has an SD code for SUDs. If you have an owner manual check it.continue to wash normally
Jul 27, 2015 | Westinghouse Washing Machines
I have a 10 year old White Westinghouse washer. I don,t know the model #. It is heavy duty. Is it direct drive , or is it belt driven
Its belt driven only washer made by the Whirlpool corp. were direct drive during that time period 10 years ago
Sep 14, 2011 | Westinghouse Washing Machines
Type of rinse agent needed for dishwasher
The rinse aid container in the door is quite large. Maybe you just stopped pouring too soon.
Sep 14, 2017 | Westinghouse 24 in. MDB421 RF Built-in...
No cold water from washing machine. Hot water is fine.
You have to replace the cold water solenoid valve.
Oct 05, 2009 | Westinghouse Washing Machines
White-Westinghouse washer will spin but water will not spin out
no its a remote electric pump,no belt.its ither blocked or fail.cut power,pop top remove frount cover an you will see pump.white or tan.remove hoses[watch out 4 water and check 4 blockage
Jan 02, 2009 | Westinghouse WWS833ES Super Capacity Top...
Clogged screen for White Westinghouse washer
the screen is located inside the water valve. you will need to take the hose of of the valve and take a small flat screw driver and pull the screen out
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
402 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
