Question about Thumper Mini Pro 2 Massager
How to replace mini pro 2 massager faceplate?
Any video that describes exactly how to replace broken faceplate? We can get parts from factory.
    New Friend:
  • 14 Answers
Not clear what you mean by faceplate. Please elaborate.
Posted on Nov 10, 2014
Testimonial: "The faceplate assembly consists of (broken) plate with 2 vibrating massaging balls. In that case it has to be replaced properly. Any error would cause Thumper to malfunction. Thanks."
  • 1 more comment
  • Edward II
    Edward II Nov 10, 2014
  • atlantis43 Nov 10, 2014
    Don't know of any videos, but removing the cover assembly (for which there are many videos available) should reveal the assembly clearly enough to enable dissembly & repair. The main (and usual)problem is the case dissembly.s
  • Edward II
    Edward II Nov 12, 2014
    Ok, thanks, Will check youtube videos.
How do I restart the massager after it overheats?
As far as I know (from my experiences with my 10-year-old model), all that is required is to allow the unit to cool off before attempting to restart.
Perhaps the company has updated the electronics with addition of a thermistor. If so, it would require replacement (but I doubt this to be so)
Sep 10, 2014 | Thumper Mini Pro 2 Massager
My massager seems to be getting louder. I have had it for three years. Is there an easy repair for this?
Question is too vague. Sounds like it will be necessary to open the case (many threads on this site for how to open it----be sure to take off the "label/screw cover) and try to identify the source of the noise, which is probably in the geared case. Replacement parts are available from the company, which gives great service.
Jun 07, 2014 | Thumper Mini Pro 2 Massager
Where can i get a thumper mini pro repaired?
Actually, you can remove the switch without opening the case, by simply carefully prying off the switch (which is actually a switch cover)
and then pushing the retaining clips of the "real" switch itself until it comes out. Then inspect & clean, and see if that solves your problem.
Another possible cause might be blown circuitry in the over-heat limiter.
May 20, 2014 | Thumper Mini Pro 2 Massager
THE TWO MASSAGE BALLS BROKE INTO ON THE THUMPER MINI PRO 2, HOW CAN I GET A REPLACEMENT
Call the company. They are very good for replacement parts, if you plan on DIY: Otherwise, they discount a replacement unit.
Apr 08, 2014 | Thumper Mini Pro 2 Massager
Thumper mini pro stopped working while in use?
Did it ever restart? If your'e not aware, there is an overheat prevention that will shut down the unit after prolonged use.
Apr 05, 2014 | Thumper Mini Pro 2 Massager
Rocker arm hums does not cycle
Do you mean that it is the motor that is "humming", and you sense vibration in the pads? Perhaps it's only from dirty contacts on the switch (which can be cleaned easily). Otherwise, it means that the motor is either broken or not being allowed to function due to breakage of one of the links in the system. For that, you'll have to open the case & check.
Feb 02, 2014 | Thumper Mini Pro 2 Massager
Where can I get the purple plastic pivoting assembly for my mini pro2 thumper massager
best to call the company & see if they have it available as a repalcement part.
Sep 06, 2012 | Thumper Mini Pro 2 Massager
Thumper will not massage
clearly you'll have to disassemble to determine the problem (if not done already). For instructions, check 'thumper repair'
Apr 24, 2012 | Thumper Mini Pro 2 Massager
It wont turn on
throw it at the wall
May 23, 2011 | Thumper Mini Pro 2 Massager
There is a long delay before the massager will acturally start to vibrate. Is this something that can be repaired?
The switch contacts are probably dirty. If you pry off the switch (actually it's a cover), you will see the actual switch underneath. There are several sets of contacts that control the speeds. Use a cotton swab wetted with 91% rubbing alcohol and clean the contacts. This made my Thumper work like brand new again. My is an older unit, and has open switch contacts. The newer models may have a different switch. This procedure was recommended to me when I called Thumper about my Mini Pro 2 not working properly. You can reach them at 1-800-848-6737.
Jul 12, 2010 | Thumper Mini Pro 2 Massager
Thumper Mini Pro 2 Massager Logo
624 people viewed this question
Top Thumper Health & Beauty Experts
john h
Mai Lor
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
