Question about Dryers
What would cause 5 dryers to all not heat up?
    Problem Solver:
  • 12 Answers
Only thing that could cause all 5 not to hear up is a blocked dryer vent hose if possible start outside where dryer vents through the wall and if not there then continue right into the dryer following the vent hose inside it has to be blocked somewhere either that or you have TERRIBLE luck buting dryer :) lol I'm almost positive you will find a blocked vent house!!
Posted on Nov 09, 2014
  • Niki Nov 09, 2014
    Thanks, the vent isn't stopped up though. I've checked that. Seems like I have terrible luck wih dryers lol. Now I have a different dryer and it won't come on at all, I thought maybe half the breaker was bad or something, so I changed that. Still no heat in the old dryer an he newer one won't turn on at all. It was working before I got it..
I have a Maytag dryer,model# mdg2706aww. Its about 5 years old, was working fine then all of asudden it stopped getting hot completely. Need it fixed but dont have a whole lot of money. What part can it be...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 18, 2011 | Maytag MDG2706A Gas Dryer
Dryer not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 29, 2011 | Whirlpool LEB6200 Electric Dryer
My dryer comes on heats for 5 min then stops heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
56
Sep 24, 2010 | Estate EED4300SQ Dryer
My Amana NDG7800AW Gas Dryer won't heat up. The dryer is about 5 years old and we have no problems with it until now. Any suggestions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Amana NDG7800AW Gas Dryer
Starts and then stops after 5 minutes and is not heating
heatman101
Sep 10, 2010 | Frigidaire Dryers
Have a kenmore 11072802101 gas dryer. it will heat for about 5 min & THEN BLOWS COLD.I replaced thermal fuse.IS IT THE REGULATOR?? OR THE OPPERATING SENSOR.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Dryers
I have a gas dryer and it will not heat. It did work for about 5 min then no heat?
heatman101
Jul 02, 2010 | Whirlpool GGQ8831L Gas Dryer
Takes 5 hours + to dry a load of clothes.
It should never take 5 hours to dry a load of clothes. If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please let me know. I hope this helps you.
Dec 21, 2009 | Kenmore 62602 Electric Dryer
DRYERS RUNS FOR ABOUT 5 TO 10 MINUTES THEN STOPS FOR ABOUT 5 MINUTES THEN STARTS BACK UP AND RUNS FOR A 5 TO 10 MINUTES .
sounds like your hi-limit temp switch is getting bad,its located on the heating element case to shut-down the dryer element so it doesn't overheat and cause a fire, they can cause problems
Aug 22, 2009 | Dryers
Roper Dryer will not heat
I don't have a picture of the rear panel available, but if you have to remove the exhaust duct to remove the panel, I would be checking to ensure the exhaust ducting is not clogged/restricted. The duct does not have to be completely blocked to cause the dryer not to heat properly.
Please take the time to give this solution a fix ya rating.
clarkco
Mar 19, 2009 | Roper REX4634KQ Electric Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
