Any reoccurring problems with the GE GTWN4250DWS?
2 Suggested Answers
emissionwiz
  • 76846 Answers
SOURCE: My ge model gtwn4250dws washer sounds like a helicopter during spinning?
The most likely cause of this is that the washer transmission has a defective bearing.
Posted on Jan 17, 2017
Jan 17, 2017 | GE Washing Machines
How do I increase water level?
The water level is controlled by the water level switch. If set to the highest fill level----thats all you get. The government has interfered with manufacturers to try and conserve water so very few of the new machines fill as high as they use to. There use to be a factory set screw on the water level switch for factory adjustments only but if you play with it wrong, you may end up flooding the basement with an over fill problem.
Apr 11, 2016 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Water drips into washer from water fill area when washer is off. How to fix that?
new fill valves usually fix that problem or just shut off Main valves when not in use
May 01, 2015 | GE GTWN4250DWS
How do I set water temperature for the rinse cycle?
I suppose you have looked at the owners manual, on the page below, it seems to indicate knob B. but it is unclear
GTWN4250DWS GE 3 9 DOE cu ft stainless steel capacity washer GE Appliances
Dec 24, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Washing machine keeps restarting its cycle
which cycle is it restarting? does it fill with water then stop or does it spin and then stop
Apr 15, 2014 | GE GTWN4250DWS Top Load Washers
GTWN4250DWS DRAINS WATER BUT WILL NOT SPIN
I just experienced this problem with this machine. I had a service tech show me how to reset it, after he checked inside the machine to make sure there was nothing mechanical wrong (you can remove the front panel with just a screwdriver or putty knife and pop it off--no screws). Here is how to reset the machine: unplug it for a minute, plug it in, then open and close the lid, making sure the magnetic switch in the lid makes contact with the machine, 6 times in 12 seconds. Then make sure the machine is leveled properly, then select a cycle and hit start. It should begin working right away.
Mar 12, 2014 | GE GTWN4250DWS
175d2750g308
They should know that info with out asking you if the are truely repair people.
Jan 27, 2014 | GE GTWN4250DWS 3.9 cu. ft. capacity top...
Washing machine start to flooded water
water valve may have grit in it holding the water valve open causing the flood.
Jan 25, 2014 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
Water level
Need new vater level sensor switch
Dec 08, 2013 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
My GE washer acts as though it is off balance but redistributing weight does not help. The surface is level and checked with a level. Any other ideas?
counterweight brick under the tub if it has broken the straps holding it in place it will make loud unbalanced tub sounds quick and easy fix
Oct 06, 2012 | GE GTWN4250DWS 3.9 cu. ft. Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
