Question about Garden
Srm 210 head frozen on end of shaft - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Did you put a pin in the gear head assy to keep it from spinning and it still wont come off ??? you'll need to dis-assemble the trimmer head assy to get in further... you will also need a new trimmer head
Posted on Nov 09, 2014
3 Suggested Answers
SOURCE: Need to remove head from SRM 210 weed trimmer
I have the same model. Home Depot assembles their trimmers then sells them, so I didn't get the stuff that comes with it. A 3/16" punch works perfectly.
Posted on Aug 24, 2009
SOURCE: Need Help Installing U-Turn Trimmer Head on Echo SRM-210
It is ridiculous, there are a bunch of bolts, and then a multi-fit brochure showing a grid of nonsense.
There are instructions on the inside of the package, however that is how to string the line.
Posted on Feb 06, 2011
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
How do you take off the nylonhead off a srm 225 straight shaft trimmer to put on a new one
The nylon head should pop off by clicking on two pins holding it to the main body. Once it pops off you should be able to reload it and push back to those clips again
Aug 14, 2014 | Echo Garden
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
ECHO SRM 210- I have removed the nylon string head and cannot find in the manual, or online, any way to attach a 22 tooth blade. How is the blade secured?
First off you have to have the blade conversion kit PN 99944200418 or 99944200418
Then you must install the kit that involves removing everything down to the angle drive mounting plate.
The blade conversion kit installation instructions are here:
http://www.echo-usa.com/pdf/documentation/99944200418%20422esf_070110.pdf
The conversion kit parts manual is here:
http://www.echo-usa.com/pdf/documentation/99944200415_011206.pdf
The users manual is here:
http://www.echo-usa.com/pdf/documentation/99944200411_101805.pdf
If by chance any of the links above do not work you can find them here: (except owners manual)
http://www.echo-usa.com/documentation.asp?Model=SRM-261T&lang=E&Type=ACC
Mar 27, 2011 | Echo Garden
I can't get the spool off of my echo srm 210 to replace the cutting line. There are no nuts or snaps that I can see. I know it should twist off, but I don't know how.
http://www.echo-usa.com/pdf/documentation/SRM210es05_112603_1.pdf
This is a link to full instructions, (page 27)
Hold body of string spool, turn smaller cap on end clockwise, as if you are tightening it, (left hand threads).
Gary
Dec 18, 2010 | Garden
How do I change the cutting line on my SRM 210 ? I do not have a manual.
You may be able to download an owners manual here as your model is a very popular one and they may have it.
http://www.manualsonline.com/
Stringing the head info should be in the manual.
Aug 29, 2010 | Echo Garden
The trimmer head does not spin, when the shaft is disconnected from the power source it spins freely. The drive componant bolted to the motor is frozen, therefore the motor cannot spin the shaft to drive...
remove shaft from power head check to see if drive shaft end is square if ok grab drive cable with pliers and try to turn head while holding pliers to make sure other end of cable and gear box are ok if so may have broke spring in clutch. remove plastic cover from engine you will see clutch bell remove spark plug stick piece of rope in hole to stop piston from moving where cable would go in bell there is a screw that holds bell on either torx or allen remove screw and take bell off there will be 2 shoes ans 2 springs that hold shoes togeather end of springs usually break where they hook in to shoe hope this helps
Aug 08, 2010 | Homelite Garden
Sep 19, 2009 | Echo Rapid Loader, Trimmer Head
Aug 09, 2009 | Echo Rapid Loader, Trimmer Head
Cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Jun 07, 2009 | Echo Garden
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
