Question about Irons
Iron not filling
Iron not filling from the generator only have it 2months
    Novelist:
  • 194 Answers
Use the warranty quick before the time runs out.
Posted on Nov 13, 2014
I bought steam generator iron, iron work but doesn’t produce steam
Mix 1:1 water and white vinegar. Fill the water reservoir with mixture and hold the iron like you would normally. Keep pushing the steam button until steam comes out.
Nov 01, 2017 | Irons
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
How to empty water form iron when finished
Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
However, if you do want to empty the iron after using it, you have a couple options:
- With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
- With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
Hope the information is useful.
Sep 23, 2010 | Black & Decker D2030 Iron
STEAM ONLY COMING OUT OF TOP HOLES SWAN S15040
The iron is probably clogged up from mineral deposits in the water. Fill the iron with a 50/50 mix of water and white vinegar. Heat the iron and let it set for awhile. Then steam the solution through the iron. Repeat the process if this does not work. If the Vinegar and water does not work, then try a product such as Lime Away or CLR to remove the deposits. After the iron is cleaned out, try using distilled bottled water in the iron, to reduce the mineral build up.
Hope this helps you!
Aug 15, 2009 | Black & Decker Steam Generator SG200 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta steam generator
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Jul 13, 2008 | Irons
No steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Jul 09, 2008 | Rowenta Steam Generator DG050 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
