Question about Star Water Systems 3/10plastic Sump Pump
Where do I get a Star water systems pump for a s1101 power flush. For my basement toilet
For my basement toilet. Power flush s1101 HP.4 AMP 5.3 HZ60 PH1. Looking for a replacement pump.
Where to buy a s1101 replacement sewage pump
Where replacement tank for 1101 power flush system
Aug 03, 2014 | Star Water Systems PowerFlush Sewage...
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Motor hums, water leaking out from under toilet,will not grind
If it is not tripping the GFCI Outlet or tripping a breaker, than more than likely the impeller is stuck. You will have to remove it to find out.
Nov 03, 2013 | Star Water Systems PowerFlush Sewage...
PEGASUS TOILET DOES NOT FLUSH COMPLETELY EVERY TIME WE SOMTIME FLUSH 4-5 TIMES
sometimes if you change the flapper and add more water to the tank by adjusting the fill valve they will flush with more power
Aug 08, 2009 | Pegasus Technologies Pegasus Toilet Paper...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
My Pressure Assisted toilet does not have the power to flush
Found this on this same site...Please let us know is it works (I'd like to know since I'm considering a pressure-assisted toilet). Solution #2 posted on Apr 21, 2009 Asker's Rating 0%20stars_w.png
noavatar_s.gif nanotick
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
May 10, 2009 | Cadet Manufacturing American Standard...
Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Mar 29, 2009 | Saniflo & Saniplus& Macerator Pump
Star Water Systems 3/10plastic Sump Pump Logo
477 people viewed this question
Top Star Water Systems Plumbing Experts
Paul Carew
Tom Chichester
Are you a Star Water Systems Plumbing Expert? Answer questions, earn points and help others
