Contact the authorized dealer for Panasonic. They might help you.
SOURCE: Panasonic TH-42PD50U Base Stand
Unfortunetly, this part has been discontinued by Panasonic. You may want to try ebay to locate this item. The part number you are looking for is TY-ST42PX5W. Good Luck!
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
