50 inch lcd HD TV rca turns on but no picture with flashlight you can see picture
    Champion:
  • 216 Answers
LIGHT BEHIND LCD NOT WORKING.
Posted on Nov 10, 2014
ThaMp3Doctor
  • 8596 Answers
SOURCE: rca 46 inch lcd tv, no sound
Go into the menu and change the HDMI Audio settings - the manual will give you a breakdown on this. HDMI is a little glitchy - if you were using red/gree/blue cables before switching to HDMI, you might want to consider going back to them - just an opinion.
Posted on Jan 03, 2009
dsacco86
  • 1077 Answers
SOURCE: clicking when turn on
The TV is trying to power up the screen during this problem.
The problem maybe a bad backlight inverter board not working or ta bad power supply.
Is it still under warranty?
Posted on Apr 20, 2009
  • 9 Answers
SOURCE: TV CODES FOR 32'' RCA HD TV
if you bought a new rca tv, the codes have changed. until the cable companies catch up, you will need to use the remote that came with our tv AND the remote that came with your comcast box. Or, you can buy a LEARNING UNIVERSAL remote. this is different than a regular universal remote.
Posted on Aug 29, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
HELP! 50 inch projection RCA HDTV. Turn it on sometimes minutes later, sometimes hours later the picture will go black with sound on once or twice and then it will power itself off entirely. None o
I got all the components you need for your tv I'm parting out mine it was oar king break when I turned it off we bought a wall hanger if you need parts call 270 589 8074
Oct 27, 2012 | RCA HDLP50W151 50" Rear Projection HDTV
2007 35" rca lcd tv L26HD35D has no picture but i
Sounds like it is probably the backlight. Turn the television on and tune to a channel, then try holding a flashlight RIGHT up to the screen and see if you can see a bit of the picture.
Aug 11, 2011 | RCA L26HD35D TV
Problem for RCA L32HD35D 31.5 inch HDTV LCD TV I turn it on and no piture just sound
With a bright flashlight see if you can see a picture.. If you can this indicates your invertor board has failed. If not more than likely your main video board has failed. Ebay has tons of parts for these tv's.
Mar 20, 2010 | RCA L32HD35D 31.5 in. LCD HDTV
Dynex dx-lcd32-09 lcd screen broke
If the LCD screen is broken, you should consider selling your set for parts. The cost of a LCD replacement is not cost effective. Examine the screen to verify.
If the LCD screen is good you can check to see if the "image" is being "sent" to the screen.
1) Take a bright flashlight and place it against the screen with the set on.
2) If you see an image around the edge of the flashlight the problem is in the inverter/CCFT or the power to it.
3) If you do not see an image the problem is probably in the LCD Controller (TCON) or its connections.
Jan 31, 2009 | RCA L42WD22 42 in. LCD Television
Blank screen beko lcd 26" lcd tv - sound ok (model no. L5A)
While you have sound, take a flashlight and shine it on the screen, look very close and see if you can see a dark video image.
Let me know what you see.
lone99star
Jan 08, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi lcd picture problem convergence issue
You need to contact an ISF certified calibrationist.
Apr 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Powers on and then right back off
Try and clean the two filters on the tv this should be the first thing to do.
Feb 01, 2008 | RCA HD52W58 52" TV
Top inch and a half of tv picture cut off.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need.  See my next post in a few minutes.
Oct 16, 2007 | RCA L32W11 32 in. HD-Ready LCD Television
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
