Question about Kyocera FS-6025MFP Laser Multifunction Printer - Monochrome - Plain Pa
I have kyocera fs-6025mfp, printing from computer & test print is perfect but when i make a copy its copying black image. may i get the solution?
    New Friend:
    Problem Solver:
  • 5 Answers
Scanner OK? When you copy with cover open see laser scanner?
Posted on Nov 10, 2014
  • 58 Answers
SOURCE: slow printine
What memory dimms have been fitted.
Print status page see top right. May need more memory and a hard drive.
cheers
Posted on May 03, 2008
idriss47
  • 26 Answers
SOURCE: Completely black copies
check the "main charger wire"
Posted on Jan 20, 2009
Cogz
  • 1326 Answers
SOURCE: Kyocera Mita 1635 Copier Printing Very Light Copies
Is one side lighter then the other side of the copy? Meaning uneven copy darkness? If so, I believe the problem is that one or both sides of the drum cartridge and the developer are not connected correctly. The two parts need to be close togather to make a nice dark copy. This model has a very wierd drum unit and has a defect that one or both side of the drum unit locking tabs break and you get very light or blank copies. It's some what coastly to replace the whole unit... That would be a worse case.... If it is just on one side you might be able to push on the cover on the side that is light. If the copies come out better. One side is broken..I would fold up some paper and make a wedge to push the catridges closer. Good Luck
Posted on Apr 16, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: my printer is flaking.
If by "flaking" you mean that the print is rubbing or flaking off then there are 2 possibilities. If you are using thicker than standard 20lb bond paper then when setting up the print job make sure you are selecting thick paper on your paper setting. This is a common problem if your paper is thicker, shiny or anything other than standard.
The other possibility would be a fuser defect of some type. But that would tend to affect standard black and white prints as well.
Try the thick paper setting as it will slow down the paper speed thru the fuser and will "fix" the toner to the paper better.
Posted on Jan 15, 2010
destom
  • 126 Answers
SOURCE: kyocera fs-2020d doesnt do multiple copies of documents
This message often shows up when the memory is full from one document (normally a large file) to fix it you have to add external memory
Posted on Nov 09, 2010
Kyocera fs 2100 keeps printing light images
It could be the transfer roller. If you have an old one you can test it with that one.
Nov 03, 2017 | Kyocera Office Equipment & Supplies
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
Black lines are appearing when i print and copy from my kyocera 1130
Your print head or some of the mechanism has something stuck in it causing the line. I would start by cleaning the print head if possible, if not you will probably have to replace the print head, but I would clean it good before I bought a new head.
Col.Dana Gillespie
Nov 29, 2014 | Kyocera Fs-1130Mfp A4 Mono Multifunction...
When i make copy its black.when i print the report its ok.can you help me?
You say you can read the report (which is internally generated so needs no light input), but what does the report say? Can you use the menu to output a check scanner diagnostic report?
Nov 02, 2014 | Kyocera FS-6025MFP Laser Multifunction...
Black copy problem
Subject: Full page solid image or error code C3200
Model: FS-6025MFP
Phenomenon: A full page solid image may appear on the print-out or error code C3200 (Exposure lamp
error) may occur.
Cause: The digital transistor in the CCD power supply circuit at the main board may be damaged,
resulting in the CCD failure.
Field measure: When the above mentioned phenomena occur, please replace the Main board with the latest type
(Parts PWB main assy).
The machine is full black when I do photocopy using a feeder(ADF) or using a glass.When I print a maintenance report using 1087 2 times then the printing is very clear.
if you can print fine and it is just when you copy from the adf or the glass then check the mirror and carriage alignment, the ccd, and the lamp. sometimes the lamp is visible but is too weak to do its job. if you replaced the drum and lsu while it still generated internal prints okay you wasted time and money.... but anyway. if you replaced the ccd and the mirrors and lamps are okay then it sounds like the board.
Sep 24, 2014 | Kyocera FS-6025MFP Laser Multifunction...
Kyocera Mita FS 1010 every few days it prints out all the pages
Format the harddrive, or go to the properties and change the setting that says leave copy on the harddrive, if all this not working try to initialize the memory and you will be fine.
double check on the driver properties check if it says direct printing or it keeps any copy on the machine.
Regards
Feb 13, 2009 | Kyocera Mita FS 1010 Laser Printer
Kyocera FS-6025MFP Laser Multifunction Printer - Monochrome - Plain Pa Logo
153 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
