Question about Tracfone Wireless Alcatel A392G
How do I turn off sound in everything but the ringer?
How do I keep the sound on ringer, yet not have to hear the click/beep sound every time I click a key?
  • 3 Answers
If you have a android phone click on settings looks a bit like a gear or flower scroll to sound select sounds and select what you want on / off (hint will have a green flag when it is on) exit by going back and you are done
cant help if you have a apple
Posted on Nov 09, 2014
Testimonial: "Thank you, Gerhard Toxopeus!"
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
I did everything except this time now it says "
Try a Restore
PS3 Recovery Menu
  1. Place the PS3 in standby mode
  2. Press and hold the power button for a couple of seconds, you should hear a beep
  3. Keep a hold of the power button for a couple more seconds, the PS3 should shut back down to standby mode
  4. Once this happens, press and hold the power button again for a couple of seconds, waiting for 1 single beep.
  5. Ignore this beep and keep it pressed until you hear 2 consecutive beeps, release the button.
Try restoring the file system (Option 3), then repeat with rebuilding the database (Option 4).
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
My uniden tect1580 doesn't ring
First thing to try is while the phone is in "On-Hook" mode, press the up key on the handset several times, you should hear a beep each time you press the button and the display should show "Ringer Volume" with a graduating series of bars. If the display shows as above, but you do not hear any rings, try pressing the "Speaker" button and listen for the dial tone. Most of the time on these phones, it is a simple matter of turning up the ringer volume, but sometimes, the handsfree speaker (Which also acts as the ringer speaker) goes bad. If the speaker is bad, it is a fairly easy replacement if you are handy with a soldering iron.
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
One beep activated
Go to Settings > Sound > Volume > Master Volume > It should say "One Beep". Then press the right arrow button and it will change settings. Change it to the Level volume option. You should have your sound back.
Mar 17, 2008 | Lands Phones
I get a loud beep on my laptop but cant hear anything else
There is a beep system in all PC's
One quick been means the computer is OK when starting.
one long continuous beep is defined as :
' Power Supply or System Board / Keyboard stuck '
Note: Alternately it could be a Memory module
However it's more likely that it's the above
If you check those two things, you are likely to find the culprit.
If not, you need to post your BIOS and
Feb 20, 2008 | Dell Inspiron 2200 Notebook
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Tracfone Wireless Alcatel A392G Logo
158 people viewed this question
Top Tracfone Wireless Cell Phones Experts
David Payne
David Payne
ka4iup
ka4iup
Are you a Tracfone Wireless Cell Phone Expert? Answer questions, earn points and help others
