Question about Archos 70 Tablets & eReaders
<!-- from fixya rte -->How to reset my password in my email - 70 Archos Tablets & eReaders
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Stuck on email and password screen. i have tried every known email and password combo. how do i reset it?
Do a factory reset . If you don't know how to do it go to you tube and enter in the search box how do I do a factory reset , or how do I reset email & password combo .
Jan 26, 2016 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
Won't send code to rest password to email
go to your email accounts you should be able to delete your email that's causing problems it should say under it forgot password then just follow the instructions you get .
Apr 21, 2015 | RCA DWA1015D - Digital Stream 10-Inch...
How do I reset my Mommy password
The easiest way to work around a lost password is to do a factory reset. Some tablets will let you change a forgotten password with an email link, but it doesn't always work. Just remember when you reset your tablet to factory, you will have to redownload any apps you installed yourself. It's just like out of the box again. Set up your new password and accounts after you reset.
Dec 27, 2014 | Nabi 2
How can I aCcess my icloud email when I cannot remember password
You can go to iCloud.com and ask to have your password reset. You however must know what email account you used when you registered. iCloud will send you a link to your registered email account, follow the link and reset your password. Write it down somewhere.
Dec 19, 2014 | Apple iPad Tablets & eReaders
Reset my password
  1. Go to My Apple ID and select "Reset your password."
  2. Enter your Apple ID, then select Next. If you don't remember it, choose Forgot your Apple ID.
  3. After you enter your Apple ID, there are three ways you can reset your password. Choose an option below:
  • Answer your security questions. Use these steps if you know the answers to your security questions.
  • Use email authentication. We'll send you an email that you can use to reset your password.
  • Use two-step verification. If you set up two-step verification, you can use it to reset your password. You just need your recovery key and a trusted device.
Dec 02, 2014 | Apple iPad Tablets & eReaders
Facebook login problems
unless you can hack it, or remember it, you won't get your old password back. You can reset it provided you still have access to the email address you have on file with facebook. Simply goto login and look for and click on, "forgot password" (or something like that!) and an email link to reset your password will be sent to you. Open the email and click on that link. Then change your password. Write it down and relogin from each place you use facebook.
Aug 21, 2014 | Amazon Kindle Fire HD
How to reset my password on my google account
Occasionally Google Gmail user may want to reset the password which used to login into the Gmail account via web, POP3 and IMAP as the original password has been forgotten, or misplaced. Gmail credentials integrates and bases on Google Account. So changing the password for Gmail will also change the password for the associated Google Account.
In order to reset and change the password of Gmail and corresponding Google Account with the affected Gmail email address, follow these steps:
  1. Go to https://mail.google.com/ (related: other Gmail URLs).
  2. Click on I cannot access my account link.
  3. Click on radio button of I forgot my password, and then click on password recovery page link (or you can go directly to the link above).
  4. Enter the username for the Gmail or Google Account in the field provided.
  5. Enter the captcha letters as shown in the image on screen.
  6. If you never login to the Gmail for the previous 24 hours, a secret question as set in the Google Account will be presented. Answer the question with a correct answer in order to be able to reset the password.
    If you're unable to answer your security question and the account has a secondary email address configured, a link will appear at the bottom of the secret question results page. Clicking on the link will has a password reset email message sent to the secondary email mailbox. After receiving the email, follow the link to reset the password.
    If you have login to Gmail in the preceding 24 hours period, the password reset email will be sent immediately instead. Follow the link to reset the password. If you don't have a secondary email address, or if you no longer have access to that account, repeat the steps above after 5 days. At that point, you'll be able to reset your password by answering the security question you provided when you created your account.
  7. If you cannot remember the answer to secret question, cannot answer the secret question correctly and do not receive password reset email in secondary email account, try to contact Google for help.
Aug 13, 2012 | Samsung Galaxy Player 3.6 YP-GS1CB -...
Tablets & eReaders Logo
37 people viewed this question
Top Archos Tablets & eReaders Experts
Joseph Prosser
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Archos Tablet and eReader Expert? Answer questions, earn points and help others
