Question about Cameras
Dropped my fine pix S I now have a black band across the screen as if something has dropped inside. inside
How do I get inside my fine pix S to see what has dropped down across the lens
  • Colin Putman Nov 09, 2014
    it is 18x zoom 12 mpix
  • Colin Putman Nov 11, 2014
    after dropping it there appears to be a slightly diagonal line across the screen as if somrthing hhas dropped down behind the lens
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Probably noting dropped down. You can not "get into" moder digital cameras. Most likely segments of the imaging sensor are dead. Take to your local camaera shop and ask.
Posted on Feb 06, 2015
5 Suggested Answers
SOURCE: Digital camera problem
I have an FE-140 open right now and i can assume it to be one of 2 things. If it was dropped it is possible that the LCD has cracked therefore you will only see above or below the crack. It s a separate part and can be replaced. The 2nd is that possibly the mylar strip that connects the LCD to the circuit board has come loose with the impact. This is quite simple to reinsert yourself, however just be careful when opening the camera. remove the 4 side screws and the 2 on the bottom(on rear casing) then gently use something thin like a nail file or sharp fingernail to breach the 2 halves and they should come apart. Never force!! Once open there are 3 more screws around the function selector that will need removing, and 2 under the corners of the LCD.The LCD will lift out to access these screws. This will give you access to the mylar strip. Good Luck,
Twitcha
Posted on Aug 28, 2008
  • 21 Answers
SOURCE: I have wo black bands across the screen on my Pentax Option 550
have you tried changing the camera's settings back to default? in the camera's menu, find 'reset settings' or 'factory settings' or something like that to reset the camera settings.. you might have messed with some settings, otherwise it may be hardware failure, may be the LCD of your camera.. hope not so.. lol
Posted on Feb 24, 2009
welcomejee
  • 10594 Answers
SOURCE: The lens is off and the camera is on. No picture.
This is known problem of bad ccd imager chip in Canon S1 IS camera and ccd imager will be replaced to get correct live view image.
Canon offers free of cost repair for S1 IS camera for bad ccd imager problem, click Canon CCD Imager Advisory for details.
Posted on Oct 13, 2009
  • 11967 Answers
SOURCE: MY daughter dropped my nikon
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 15, 2010
Why does Kodak Pix Pro show black screen after being lightly dropped?
Unfortunately, even lightly dropped can cause problems if it lands just the right way. For instance, at my work, I have dropped my smart phone numerous times, including onto bare pavement and never a problem. Another guy at work, knocks his off a 12" patio table and the screen shatters. It could be as simple as a knocked loose connector inside.
Jun 14, 2015 | Kodak Cameras
Screen issue for dell inspiron 5110, I dropped my laptop earlier today fron about a foot n a half drop, the back of the screen is what hit the ground first, the screen was fine though, not shattered but it...
The screen's connection is loose or something is broken inside. I suggest that you have it checked by a technician but if you can do it, then you better check the connections.
I hope this helps!
David
Jun 07, 2013 | Computers & Internet
I have a toshiba 61h70. the tv had been shutting down after and few minutes and the red bulb was flashing also. I replaced the IC Chips and it resolved the flashing and shutting down issue. the green and...
You need to look with a meter at the resistors around the chips, they are usually gray in color with bands that denote value--a good guess is one or more were taken out by the chips--in these sets they will look fine---typical is 1.8 ohm (brown, gray, black bands).
At least one is open (bad--no reading across--like checking a fuse) and there will be several with identical color bands on them.
Let me know if I can help.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 16, 2010 | Toshiba 61H70 61" Rear Projection...
Bottom screen black
Your bottom lcd is busted. It'll have to be replaced.
Look online for Nintendo DS bottom lcd replacements.. Fairly cheap
May 17, 2009 | Nintendo DS Lite
Feb 24, 2009 | Pentax Optio 50 Digital Camera
Toshiba CF2772B New in 1992. Has black band across the bottom
If the pix was good up until this point, I would take the plunge and repair it, even though it may be close to 200 US...accordianman
Nov 11, 2008 | Toshiba 27A33 27" TV
Sony LCD projection tv
you need to set up format and far your turn off your computer
and restart it and so cpu can pick your tv i have a 40 kdl40s2000
and i used it for my 360xbox computer vire nice pix h/d
Apr 01, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Acer TV Plasma screen problem
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Dec 31, 2007 | Televison & Video
White bands appearing across pictures
Mikrofiber towel and a few drops of wather.
Clean the lense even if looks clean.
Try to reset the camera in the menu to the factory settings.
If not help service only.
Nov 11, 2007 | Canon PowerShot S230 / IXUS 179 Digital...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
