Question about Bosch Dishwashers
SCREW SIZE TO ATTACH TOEPLATE ON BOSCH DISHWASHER
MODEL SHE55R55UC/64
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
I have install those but its been a while I think is the same as #8 Machine Thread >>>>
Posted on Nov 09, 2014
Testimonial: "thanks"
3 Suggested Answers
  • 11 Answers
SOURCE: Securing Bosch SHU 4300 under "hard" countertops
If this is a new Bosch Dishwasher then there should be two metal tabs that protrude from the top of the tub above the door. These tabs are for top mounting the dishwasher to a wood countertop, however these tabs also can be relocated to side mount the dishwasher to the cabinetry. The way to do this is to pull the dishwasher out of the hole it is in, in the counter (be careful not to pull too hard or to move the machine out too far due to the length of the water and electric lines). just pull it out easy till you can see the tabs, Now using a pair of pliers, bend the tabs on the backside of the mounts straight so you can remove them from the framing of the dishwasher. Next look at the tabs there should be a perforation where you can use 2 pairs of pliers to snap the tabs off at the perforation, after snapping off these tabs, look at the sides of the dishwasher and you will see a slot where you can reattach the tabs into, and bend the tabs in the back to hold them in place. If you look at the rubber gasket material on both sides of the machine - you can see where the round holes are located for side mounting. Attach the tabs and gently push the machine back into the cabinetry. Now using a small drill bit, drill a pilot hole into both sides of the cabinets to mount the dishwasher. You want to drill these pilot holes so as not to split the counter facing when you drill in the screws. Using the Bosch screws that came with the dishwasher (or small flat phillips screws) slowly screw in the screws into the sides of the cabinetry. When you attempt to remove the machine from the cabinetry you may find that it is adjusted tight to the countertop. If this is the case you will need to remove the 2 screws that hold the kickplate in at the bottom of the dishwasher in the front and remove the kickplate. Then you will need to bring up the front legs on both the left and the right and also the rear leg which is adjusted up and down by using a flat blade screwdriver. Look at the front of the dishwasher, behind the kickplate and there will be a adjusting screw with arrows which point left to right. the direction you turn this screw will determine which way the dishwasher will adjust,- right adjusts the machine higher and left lower. Good luck!!!!!! Hope this helps.
Posted on Feb 05, 2009
here2helpBSH
  • 27 Answers
SOURCE: I need the size of the screw for the inside door of Bosch SHU43C0
M4x11 is the size. but you dont need the exact screw really. if your worried about the door making a seal when you close it. it seals before it hits those screws. use stainless steel screws only so it doesnt rust. (non-magnetic)
Posted on Mar 19, 2009
Where is the FLOAT located on my Model SHV55R53UC/64 BOSCH DISHWASHER
I would type all your product information into "SearsPartsDirect", and you should get a picture of the machine.
That set of pictures will tell you if there is a float or not.
There is a phone number you can call, also, and ask them questions about this.
God bless your efforts.
May 22, 2017 | Bosch Dishwashers
We have a Bosch SHE45M06UC/50 in an island with a granite countertop. It is not attached and so moves. How do we attach it to the granite countertop? Or how do we attach it????
You glue on a wood strip, to the underside of the counter, then screw into that. Use construction adhesive. The wood strip needs to stick down no further than the counter edge treatment, so you normally cannot see this wood strip.
May 11, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
What is the size of this screw
click on : http://www.espares.co.uk/advice/dishwashers/a/3
Mar 08, 2011 | Bosch Dishwasher Screw 176121
Just did a kitchen remodel, kept the Bosch dishwasher model SHU9955UC, contractor having problems will attaching dishwasher to granite. Any suggestions? Thanks!
Ask a local granite fabrication shop to get you some dishwasher mounting clips. They look like a perforated disc of metal with a small nut brazed to one side. They come with a short screw that attaches through your dishwasher mounting tabs. Place your dishwasher where you want it relative to the cabinets and pick a hole in the mounting tabs that won't leave the clip protruding and attach the clip to the chosen hole. Use masking tape on the top of your dishwasher door, wipe the bottom of the granite and the top of the clip with acetone, then use a gel-type two part epoxy from your local hardware store to attach the clip to the granite. Use enough to make the epoxy push through the perforations in the clip as this is how the epoxy grips the clip. Push the clip to the bottom of the granite and close the dishwasher door, using a wood shim or two between the top of the door and the mounting tab/clip to push the clip tight to the granite. Pull the shims out once the epoxy has cured (check the instructions on the epoxy).
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Sep 24, 2010 | Bosch SHU9955UC Built-in Dishwasher
Hello,what tool do you need to remove the screws in the bottom of my bosch diswasher,they seem a odd shape.
Hello Steve, The screw heads should be a "Torx" size T20. Hope that answer's your question. Good luck. Macmarkus :)
Jun 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Looking for a video on how to make and install a custom door panel for 18" bosch dishwasher
no video but it is easy to do .take off screw around the door and replace panel insulation on some model and replace panel.
Feb 23, 2010 | Bosch SRV53C03UC Built-in Dishwasher
Bosch dishwasher won't drain model SHU3302uc/17
probably something stuckin drain pump. remove plastic part in bottom of unit with a torc screw driver spin the propeller and your problemis solved. let me know if it works.:]
Dec 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Mar 19, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Feb 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
64 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
