Question about Panasonic CQ-DP102U CD Player
<!-- from fixya rte -->How do I set the time on my CQ DP102u? - Panasonic CQ-DP102U CD Player
I set the time on my Panasonic CQ-C5301U CD Player 2 years ago... now it is an hour fast and I completely forget how to set the time on it! how do you set the time?
You may find this link to manual download will work just fine.
https://panasonic.ca/PDP/OperatingInstructions/cqc5301-5401-oi-eng.pdf
Feb 18, 2011 | Panasonic CQ-C5301U CD Player
Set time car radio/cd Panasonic CQ-C13367
First of all, go to service.us.panasonic.com/operman to get the manual for your unit.
With the unit turned on and the clock displayed, pres disp for more than two seconds. The hours will blink... press < or > to adjust hour. Press disp again, the minutes will blink... press < or > to adjust minutes. Lastly, press disp to store the correct time. Good Luck!!!
Nov 09, 2010 | Panasonic Car radio CD CQ-C1110GN CD...
I accidently erased the memory on my panasonic cq-vd701u how can i restore it?
There is no way to restore the memory that was erased as there is no temporary back in the set.
You will need to reset the memory once and take care of any accidental erasing next time.
Oct 27, 2010 | Panasonic CQ-VD7001U Car DVD Player
I have a cd stuck inside my player will not eject how do i get it out
You have no choise at this time but to open it or take it to a repair shop to have them fix it or just remove the cd. by opening it up you can finagle the cd out, good luck
Mar 05, 2010 | Panasonic CQ-DP102U CD Player
NEEDING A WIREING HARNESS TO INSTALL MY CQ-DP102U PANASONIC. THANK YOU
You can check out the parts available from Panasonic at thier web site - here's the page with the parts list that are still available: http://www.pasc.panasonic.com/Epartr/PartsList.asp If you don't want to do that - I'll buy the unit at a reasonable price. The unit in my motor home that I just bought doesn't work and the wiring harness is integral to the dash wiring harness since it was factory installed so I want to replace the unit with an identical unit. eMail: Gene-Bostwick@Comcast.net
Nov 05, 2008 | Panasonic CQ-DP102U CD Player
Setting time
You can find a copy of the manual at http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelDetail?surfModel=CQ-C5305U&catalogId=13401&cachePartner=7000000000000005702&modelNo=CQ-C5305U&itemId=112163&catGroupId=25028&surfCategory=CD+Receivers&cacheProgram=11002&storeId=15001&displayTab=R It has the instructions in it on how to set the clock.
Aug 04, 2007 | Panasonic CQ-C5305U CD Player
Panasonic cd "No disc"
The player cannot read the data on the CD. The laser maybe dirty or defective. Before sending for repair try to use a disk cleaner.
May 23, 2007 | Panasonic CQ-DP102U CD Player
Setting clock
Here is a link to your manual: http://service.us.panasonic.com/OPERMANPDF/CQ-DF802U.pdf The instructions for setting the clock are on page 27.
Apr 05, 2007 | Panasonic CQ-DF802U CD Player
Panasonic CQ-DP102U CD Player Logo
76 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
