Question about Philips GoGear MP3 player SA2SPK04K Spark 4GB with FullSound
My device will become on only when it is connected to charger. and it remains on till it is connected to charger
I havn't usemy device from last 2-3 years as it was lost. but recently i found it somewhere at my home but i guess its time to replace its battery. so from where i should open my device. Please help!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Battery is bad and take it to a radio shack
Posted on Nov 09, 2014
How do i pairing a tl7600
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109 !!!
If you have been going nuts on how to pair TL7600 with TL86103 or TL86109 Deskphone, here is a detailed answer.
First of all TL7600 does not need pairing, it is a passive wireless i.e it remains in hunt mode till a deskphone actually pairs with it.
First things first - Charge the Dect Headset TL7600 for 1-2 hours. Press the On/Off button once and you will see a blue/red light that will keep blinking every 2-3 seconds. This shows that the headset is unregistered with the Deskphone. When the headset becomes properly paired and placed on the charger, it will show steady blue light.
Okie, now to registering the headset.
a) First, lets reset the TL7600 just incase it was paired to another phone. Even if it is not, lets just do a reset to avoid some problem.
Push these buttons in the following order one by one :
Push these buttons in the following order:
vol+mutevol-mutevol+vol-mute
b) Go to the TL86103 and keep TL7600 very close to it. Lift off the TL7600 off the charger and then put it back in.
c) Press "MENU" on telephone mode with phone handset on the phone and the phone in Idle Mode.
c) Scroll to "Settings" and then scroll to "Register"
d) All this while, the TL7600 should be on the charger. If you remove it from the charger, it will not register.
e) Within 90 seconds to 2 minutes, the headset will be registered and you will see the handset will be assigned a name on the phone.
f) Pick up the headset, switch it on and you will hear a dial tone.
g) If this doesnt work, try to first press hold for 10 seconds till it says "Unregister All Devices', Click Yes and go through the process again.
j) If you want to know how to make a call, please note that the call will have to made first on the deskphone, then switch on the headset and there you go. Either lift the reciever and make a call or press Speaker and make a call and then switch on the headset, put the deskphone handset down or switch off the speaker and your TL7600 will be connected.
*** For TL86106, everything is same till (b). After that, press HOLD Button on the phone for 4-5 seconds till you see "Registering". Within 90 seconds to 2 minutes, the device will register the TL7600.
Nov 07, 2013 | AT&T TL7600 Wireless Headset
TL7600 Headset will not pair with TL8802 base
*** How to Pair AT&T TL7600 with AT&T 86103 or 86109/TL88002 !!!
*** FOR TL86103, do the below (See below for other models)
FOR TL86106, 86109 and 88002, do the below steps.
Aug 06, 2013 | AT&T TL7600 Wireless Headset
Tmobile dash isn't turning on
  1. Verify that the OEM Charger and Battery are being used.
    • Only the AC charger, Car charger, or USB data cable that came with or was created for the device should be used; others can damage the device and/or battery.
  2. Is the device warm?
    • When using the device for prolonged periods of time, such as when you're talking on the phone, charging the battery or browsing the web, the device may become warm. In most cases, this condition is normal and therefore should not be interpreted as a problem with the device.The device has a protection feature that if the device becomes too warm (due to use of GPS while charging, BT while charging, using the device as a wireless modem, etc), the auto protection feature will be triggered and the charging process will be stopped. Once the device cools down, the device will then begin charging again.
  3. Check the USB Port on the device for any bent or misshapen PIN's.
    • If some are found, that is the most likely cause and this is considered physical damage not covered under the Warranty.
  4. Remove the battery and inspect the contacts.
    • Remove any debris/residue found on the device or battery contacts with a soft, dry cloth.
  5. Look closely at the battery contacts on the phone to see if they are bent out of shape.
    • If they are bent, the device will need to be exchanged.
  6. Try charging the device (try different power sources as well as chargers):
    • Plug in USB to device and PC; is the LED indicating that the device is charging?
      • Note: If the device isn't charging while connected via USB to a PC, go to Start>Settings>More>Power>Power Management and make sure that "When device is turned on, do not charge the device when connected to the PC" is set to OFF.
    • Plug in AC Charger to device and outlet; is the LED indicating that the device is charging?
      • LED indicators: Charging is indicated by a solid Amber light on the upper Left side of the face of the device.
        • Note: If the battery is completely dead, the light will be a solid RED for a few seconds while it is charging; once the device has enough power to turn on, the light will turn to Amber.
  7. Try another Power Source.
    • Try a different outlet to rule out that as the issue.
  8. Try another battery in the device.
    • If another battery doesn't work, perform a Hard Reset.
      • If the device powers up after Hard Reset, test the unit for a few days. If issue returns, device can be considered for an exchange.
      • If device shows charging with one (AC Charger or USB) and not the other, issue is with the accessory. Replace accessory.
      • If device will only power up when attached to charger (AC or USB) it is likely the battery needs to be replaced.
Device won't hold a Charge
The life of the battery between charging sessions will vary depending on which features of the unit are being used.
  1. Verify the you are using:
    • OEM AC Charger
    • OEM USB Data Cable
    • OEM Battery
  2. Fully charge the battery using the OEM AC Charger
    • USB and car chargers are trickle chargers meant to get the user through until they can get to their AC Charger.
  3. If the device is not lasting the advertised Talk time, with minimal use, try another OEM battery in the device.
  4. If the battery life still is not meeting the advertised Talk time (with minimal use), the device will need to be repair/replacement.
Device won't Power on
  1. Attempt to charge the device.
    • If the battery is dead, the device will need to charge for a few minutes and then should power on once this happens.
  2. Attempt to power the device on by pressing the Power Button for 3-5 seconds.
    • If the device doesn't power in, perform a Soft Reset using the stylus.
  3. If the device still doesn't power on, perform a Hard Reset.
  4. Try another battery.
  5. If the device still will not power on, it can then be considered for repair/replacement.
Handset Powers off
  1. Make sure that the device is actually powering off and not just going into hibernate mode by pressing the power button once.
    • If the screen comes back on, the device is not powering down.
  2. If possible, check the battery level by going to Start>Settings>More>Power>Power Management.
    • The charge should be no lower than 10%; if it is, charge the device and retest.
  3. Try another battery in the device.
    • If the device stays powered on with a different battery, the issue is with the accessory not the unit.
  4. If the device still powers off with another battery, Hard Reset the device and retest.
    • If the issue remains after the Hard Reset, the device it can then be considered for repair/replacement.
Nov 13, 2010 | T-Mobile Dash Smartphone
The navagation part of the gps is stuck and will not move past the opening window
tThere are two possible causes depending on the accuracy of your description.
1) your map does not access the satellites, therefore the last known location or your home location remains on the screen.
a) Battery is too low to access satellites, recharge using AC Charger prior to use on DC
b) The SIIRF chip is damaged. Costly to repair!
c) Your maps have become damaged.. If all you get is the LOGO of the GPS or Maps then the problem is damaged software.
Jun 30, 2009 | Nextar X3-02 GPS Receiver
Battery
Sorry to hear that you have no spark on you bike. Just a quick thought have you measured the battery voltage could your charger have damaged battery. I over charged my battery last year ( would only produce 8V) and had to get a new one along with an Optimax 3 charger so it would not happen again.,,
Nov 10, 2008 | 2005 Hartford VR 200H
I Have an Acer Aspire laptop and evertime you plug in the charger it will show no signs it's connected and the laptop is now out of battery so it will not turn on at all. Even when my charger is plugged...
Please Please Please change your charger right away .. I Got 2 Acer laptop last week and both had same probelm ..if there would be any fluctuations in voltage from your adaptor it will fry up your laptop and you will be in big trouble. Please dont do any experiments on your adapter and change it right away. I Got one laptop last week and customer tried so many angles like you did and fried up his laptop's motheboard already.
Hope you will listen to my suggestion. new charger is not very expensive.
Good Luck !!
Sep 30, 2008 | Computers & Internet
Garmin 200w does not hold charge
Hello Jeffery81,
Sounds like either a bad charger or a bad rechargeable battery pack inside of the GPS. If the unit doesn't remain powered up even when it is plugged into the charger, my guess is that the charger is the problem. Do you have an alternate way to charge the GPS? Like a 12 volt vehicle power cord or a USB cable to connect it to your computer? If so, try charging the GPS using that alternate method. If the item charges and functions normally, you will know for sure that the problem lies with the charger. If not, then the problem is either the battery pack inside the GPS or some other part of the unit's charging circuitry. In that case, you should contact Garmin technical support for additional assistance.
Best Regards,
Ken
"Go Ahead. Use Us."
May 19, 2008 | Garmin nuvi 200W GPS
TomTom 910 charger question
Yes, you can.
I presume the charger has an USB connector.
5v and 2A are the correct figures for a Go910.
Aug 24, 2007 | Tomtom GO 910 GPS Receiver
Philips GoGear MP3 player SA2SPK04K Spark 4GB with FullSound Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
