I have a smartwash quietpak 9, what does F25 mean?
jsrock516
  • 5911 Answers
SOURCE: Door stuck Locked Control Locked light on
Try unplugging the washer for at 30 minutes to reset the computer, first. If this proves unsuccessful, you can retrieve you clothes by using the manual release. The following link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Once you retrieve your clothes, try running diagnostics on it. You can envoke the diagnostic sequence by selecting DRAIN/SPIN, NO/SPIN and then pressing any button under OPTIONS 4 times (must be the same button). The display should go to "C00" as the washer begins a sequence of tests that checks the fill functions, door lock, dispenser functions, motor speed, spin and drain. Allow the washer to run through the entire sequence and shut off. If anything is wrong an error code should be generated. Hopefully, all you had was a minor glitch. Let me know how things turn out. I hope this helps you.
Posted on Aug 25, 2008
  • 91 Answers
SOURCE: Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Posted on Jan 02, 2009
jsrock516
  • 5911 Answers
SOURCE: i have a kenmore elite smartwash quietpak 9 HE4t.
The following link explains how to correct a Control Lock problem on a Kenmore Elite:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
Some front panel features differ between models, but the instructions should be listed on the front panel of the washer, and are located in the operator/owner's manual. If these preliminary measures do not work, you may have a mnore serious problem.
If you have any questions, please let me know. I hope this helps you.
Posted on Aug 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore smartwash quietpak 9 HE 4T washing
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a sears kenmore elite smartwash quietpak 9
Kenmore smartwash quietpak HE4t does not complete cycle and flashes F then H continuously
From what you're describing it sounds like the cold water line is blocked or restricted or the inlet electro valve is defective.. Most rinse cycles are cold fills. Another possibility is the drain hose is air tight or too low creating a siphon condition
Jan 05, 2017 | Kenmore Washing Machines
Kenmore elite he3t quietpak 4----F25 ERROR CODE...WHAT NOW??
The F25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then re-seat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
Oct 28, 2011 | Kenmore Elite 45986 Front Load Washer
F 02 error on kenmore smartwash quietpak 9 front loader washer
F02 - Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the bottom front edge of the lower toe panel directly below the door. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains: checking_the_drain_pump_on_a_front_loade
Press PAUSE/CANCEL twice to clear the display:
Check the drain hose and make sure it is not plugged or kinked.
Check the electrical connections at the pump and make sure the pump is running.
Check the drain pump filter for foreign objects.
If the above does not correct the problem, replace the pump.
Hope this helps (remember to rate and comment this answer).
May 05, 2011 | Washing Machines
My HE3 kenmore elite quiet pak2 will not empty out water and spin
This due to the drain pump either being clogged or having a broken pump rotor. You can access the pump to check this by removing the bottom front panel by removing the 3 screws under the panel. You will need some towels bacause you will have A LOT of water come rushing out when you unscrew the drain pump cleanout. If this cleanout is clogged, remove the obstruction and test the washer, if there is no clogg you will need a new drain pump, this part can be ordered at, http://www.reliableparts.com/ by using your model number to lacate the pump. It is very easy to replace, just be sure to disconnect the power to the washer first =)
Please rate mt solution if it was helpful to you.
Thanks, Repairman45
Dec 15, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore smartwash quietpak 9 HE 5T front loading washing machine for about 2 years. Today I did a load and the water will not drain from the washer so I had to pull the clothes out and wring the...
Likely the drain hose is kinked or blocked...Or the pump filter blocked or pump is faulty. Most likely the filter needs to be cleared. This should be accessed via a small hatch at floor level. Or behind the kickplate. unscrew filter and clean. Make sure the machine has no water in it. Leaning it back against the wall will help with visual inspection as well. Make sure coins haven't jammed in impeller. Good luck.....Nomess
Apr 18, 2010 | Washing Machines
Error "F6" on my Smartwash Quite Pak9
I believe the F6 code is a motor failure. I suggest you call a pro to come out and look at it.
Sep 22, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite smartwash quietpak 9 HE4t. The control locked light is on. I have tried unplugging for an hour and plugging back in, door is unlocked but no buttons work. What can I DO
Aug 23, 2009 | Kenmore Elite HE5t Washer
Kenmore Elite QuietPak 9 Dryer - door opens constantly
I'm not solving the problem, but just wanted to say I have the same problem for the same dryer
Aug 04, 2009 | Kenmore Elite HE4 Electric Dryer
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
