Question about Irons
My head Black and Decker, model number ICR515, self cleaning iron, will not turn back on, after I hit the self-cleaning button, and cleaned the iron for the first time.....
    Novelist:
  • 194 Answers
This should be under warranty. Start that process or work with the place of purchase.
Posted on Nov 13, 2014
3 Suggested Answers
SOURCE: Cleaning a self cleaning iron
Fill the Iron with water but keep the water level below the max line. Plug in the iron and set the temp to 6 and stand iron on it's heel and allow to heat for 3 mins. Now unplug the iron and take it to a sink move and Hold the variable steam dial in the CLEAN position. There may be some hissing and spitting while cleaning so be careful. Continue to hold the dial in the clean position until all the water has emptied. If necessary rock side to side and back to front to get all the water out.When finished release the steam dial plug in the iron and heat for about 2 mins to dry out the remaining water and unplug.
Posted on Jun 16, 2007
  • 1566 Answers
SOURCE: I hit the Self clean
Could you please tell us the exact model of the iron?
Thank you.
Posted on Oct 03, 2010
Just plugged in brand new iron and the variable steam dial won't move
please take it back, it will only give you more problems. irons are not made as well as they use to be.
Jan 24, 2015 | Black and Decker USA Applica Black &...
How do I clean a not self clean ,quick press s506a , not self cleaning black and decker steam iron
Most steam irons can be cleaned deposits by emptying the water and replacing with white vinegar. Let it heat up and use the iron as normal - but on cloth rags instead of clothing. The vinegar breaks down and dissolves the mineral deposits inside that are responsible for sputtering and stains. You can reduce or even eliminate these deposits from forming by using distilled water instead of tap water in the iron - otherwise - run vinegar thru it when it starts acting up. The vinegar "trick" works great on coffee makers, too.
Dec 03, 2014 | Applica Black And Decker Steam Advantage...
Water shoots out when trying to steam.
You are getting a lime (scale) build-up in the iron. Best to try a clean, either with a self-clean function, or buying a lime remover solution for kettles and irons.
Dec 09, 2010 | Black & Decker D2030 Iron
The Clean light on my Black & Decker Digital Advantage iron has come on and I can't find my manual. How do I 1) clean it and 2) get the light to turn off?
I found a previous answer on FixTa.com that had a link to the owners manual for my iron. The info I needed was there and my problem is resolved!
Jan 12, 2010 | Black & Decker D2030 Iron
How do I clean my Black N Decker Advantage Iron
I work for Black & Decker customer service. Our number is 800-231-9786.
You can obtain a new manual for free by visiting www.useandcaremanuals.com. Below is the section from the manual on care and cleaning of your iron.
Care and Cleaning
This product contains no user serviceable parts. Refer
service to qualified service personnel.
It is not necessary to empty the water reservoir after each
use of the iron, if you iron frequently.
To empty the iron, hold the iron over the sink with the tip
pointing down. Water will stream out of the water fill
opening.
TO CLEAN THE OUTSIDE SURFACES
• Unplug and allow iron to cool completely. Wipe the
soleplate and outer surfaces with a soft cloth
dampened in water and a mild household detergent.
Never use abrasives, heavy duty cleansers, vinegar, or
scouring pads that may scratch or discolor the iron.
• After cleaning, iron with steam over an old cloth to
remove any residue from the steam vents.
ABOUT THE SELF-CLEANING SYSTEM
• Use the self-cleaning system to flush out minerals and
lint. If lint is allowed to accumulate in the vents, it can
scorch and cause brown spotting.
For Models D2000 and D2020: Clean about once a
month.
For Models D2010, D2030 and D2035: A "CLEAN"
indicator will appear in the digital display to notify you
when your iron needs cleaning (A).
• Fill the iron as described in "How to Use" but keep the
water level below the MAX line. Plug in the iron, set
the temperature to 6, and stand the iron on its heel
rest. Allow to heat about 3 minutes.
• Unplug the iron and take it to a sink. Holding it
horizontally over a sink, move and HOLD the variable
steam dial in the CLEAN position ( ). There may be
some hissing and spitting while self-cleaning. This is
normal.
• Stay clear of HOT steam and boiling water as it comes
out of the vents while lint, scale, and minerals flush
through! Continue to hold the variable steam dial in
the CLEAN position until all the water has emptied.
If necessary, rock the iron side to side and front to back
to empty it.
• When finished, release the variable steam dial, stand
the iron on its heel rest, and plug it in. Heat for about
2 minutes to dry out any remaining water then unplug.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 03, 2009 | Black & Decker D2030 Iron
How do i use the self cleaner
Care and Cleaning
opening.
month.
normal.
to empty it.
Jun 26, 2009 | Black & Decker D2010 Iron with Auto...
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
May 22, 2007 | Black & Decker D2030 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
