Main blower runs all of the time.
Replaced control board. Burner and combustion motor kicks in when heat request is activated. May I change the blower motor wires to the LOW speed terminal or is the fan switch stuck closed at the thermostat? No error codes. Blows cold air during non-heat cycle. Old board would not engauge main blower only.Worked if combustion cycle started and I provided external power to main blower motor with thermostat hot-wired/bypassed. Dave in Seattle.
  • Heating & Co... Master
  • 1,099 Answers
If you bypass tstat, meaning hot wired blower, does the blower cycle on and off by touching and removing red with fan?? If yes than obvious problem in tstat. I was leaning towards a bad relay but if you can make it work by passing tstat, there's you problem.
Posted on Jun 23, 2017
hotuna
  • 288 Answers
SOURCE: Goodman Furnace Intermittent
Does this piece, have an economizer and or vent draft options installed? I hope not. If not, I had the same sort of problem with a Payne unit, sort of the same style. First things first. bypass the thermostat by making a jumper or connecting the red to the white wire on the thermostat, see if that stops the problem. Repair techs are all to anxious to replace the board anymore. If the repair man installed a relay to bypass the blower control he is in over his head, the limit switch determines when the fan shuts on & off based on temperature. There is a relay on the control board that basically carries the load for the motor. Dont have anything else installed that need not be there (there is enopugh crap already from the factory) If you want to really fix this I need to know if you have and can read a volt/ohm meter and can understand a wiring diagram, hopefully yours is still there. let me know after the thermostat thing and I can walk you through this.
Posted on Dec 25, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Posted on May 30, 2008
wbwill
  • 68 Answers
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Posted on Nov 22, 2008
farfield
  • 462 Answers
SOURCE: replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Posted on Mar 13, 2009
  • 9 Answers
SOURCE: Heater Burner ignites but main blower motor will not turn on.
it sound like the blower motor may be seizing up. try spining the blade by hand to see if it feels free or not. the motor could be trying to turn but can then tripping itself out on overload. (most motors have built in safety overloads which will trip during an overcurrant event. aka too many amps.) you may have to replace blower motor
Posted on Mar 22, 2009
Combustion blower motor runs all the time
I'm assuming what you call a combustion motor is actually the idm(induced draft motor) which is the 1st action in a gas fired furnace, clearing any residual fuel from heat exchanger then forcing the flue gas to the outdoors. This IDM is controlled, normally, by the furnace control board(circuit board). May need a new board.
Nov 16, 2015 | Heating & Cooling
Furnace kicks out every so often, ran for two days this time, then kicked out on a pressure switch open, i have replaced the combustion motor ,pressure hose ,and pressure switch, runs for a while then...
You are going to need a service man. A magnehelic gauge is needed to properly diagnose a pressure switch issue. Could be a blocked or restricted flue, a defective induced draft motor, cracked heat exchanger, restricted secondary heat exchanger, ect. ect.
Feb 21, 2014 | Intertherm 56000 Btu Gas Furnace
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
I have an older Carrier furnace type 58ss. The main burner will not ignite. Operating look ~ thermostat set @ 78 deg, switch furnace on, inducer fan running, pilot light clicks and ignites, inducer still...
power to gas valve ok .. Replace gas valve after checking gas valve coil for continuity/resistance... with valve removed ...and power to valve ... try blowing thru valve from supply side ... stuck valve.... replace...
Nov 01, 2013 | Heating & Cooling
Just replaced idnitor and flame sensor on a bryant model 376c and its still not kicking on. blower kicks on fans kick on and then cycles off. no heat need help
Make sure all wires are connected and the gas is on. Follow the sequence of operation for this model and a few tips on what could be the issue.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 27, 2010 | Heating & Cooling
Have a Goodman GMT070-3B which the vent motor seems to be sticking. I took apart and cleaned the brushes and reassembled. The furnace will come on only after what seems like the vent motor comes up to...
The whole assembly must be replaced.
The sequence of operation is -
Combustion fan purges the heat exchanger. A pressure switch verifies combustion air fan is running. Usually a 30-45 second purge before the hot surface ignitor glows, or the spark ignition starts.
Gas valve opens after 10-15 seconds and main burners light. Control board monitors for flame and shuts gas valve after 2-3 seconds if main burner does not light.
If burner does not light, some boards repeat this for 3 tries, then locks out and is reset by cycling power.
Air blower comes on after another 30-45 seconds after main burner ignition.
Times may vary based on the specific controller board. A flow chart and timing sequence should be located somewhere on the unit, usually in the fan compartment.
Dec 16, 2009 | Goodman GMS90703BXA Heater
I have a GMP100 furnace and I replaced the control board because the blower fan wouldn't kick off now and then. It all works great but the main blower only stays on about 45 seconds after the burner turns...
Check the board for a set of dip switches. Check against the old board for switch positioning. These control fan on/off times. Ensure you turn power off before changing switch positions. If no dip switches,??
Dec 04, 2009 | Refrigerators
Ruud furnace Model URKA A030jK08 Code opt 589
Flip the lower panel over and look for a wiring diagram. On that diagram there will be a diagnostic chart. Let me know what 5 blinks represent. Then I want you to read on.
Nov 23, 2009 | Heating & Cooling
I have a Rheem (Criterion) unit and i'am having promblems with the main burner staying on. When i turn the unit on everything operates like it should up to the main burner staying on.Once the main flame...
Run a wire from the sensor down to the control board conector. Bypass the sensor wire around the connector in the blower deck.
The connection can be wire nutted on the sensor lead with the wire (16 or 18 guage stranded wire works) routed through the blower deck to the other side of the plastic wire connector on the blower deck.
The Sensor operates at high voltage but very low current. The connector will sometimes fail due to humidity or wear.
I have seen this on the Rheem or Ruud furnaces.
Hope this helps.
Matt
Jan 07, 2009 | Heating & Cooling
I have a problem with my heating system. It is about 10 years old and has had the ignitor, combustion blower motor, and programable thermostat replace in it's lifetime. The system worked great last year....
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
