Question about Kenmore Kitchen Ranges
Bake/broil isn't working. could it be the thermostat? if so, how do I replace it?
  • 1 more comment
  • Tony
    Tony Nov 10, 2014
    Gas or electric?
  • lori guerrero
    lori guerrero Nov 10, 2014
    electric
  • lori guerrero
    lori guerrero Nov 11, 2014
    120 going to each side of the element to total 240
I would look more toward replacing the igniter. You have not really given enough information to be sure what the problem is (Does it heat at all? Does it take forever to get to 200 degrees (or something like that)? and without the model number; or even if the range is gas or electric there is no way of giving you specific instructions on how to change it or what it looks like because there are so many different ones on the market. But the igniter is pretty easy to replace; 2 screws (usually) with connected wire(s) If you have a gas range, you may need 1 igniter for the oven and one for the broiler. (Both of mine were out at the same time and that seemed so impossible before I replaced them. But it is fact) .
The thermostat is not testable and the only way of knowing is to replace it because it is also not servicable. You can look to see if the igniter is glowing once your have turned the oven/broiler on. But, even though the oven igniter may be glowing, it may be too weak to allow the gas valve to open. If the oven broiler igniter glows for more than 90 seconds without igniting the gas flame, the oven broil igniter should be replaced. This is the most common part that fails when there is an oven broiler problem. If you still have the manual that came with your range, there is probably a parts list. If not, google "oven igniter" + (your specific model number) and also "broiler igniter" + (your specific model number). Then you will know if you need 1 unit or 2. OEM parts (Kenmore, Maytag, GE, etc) are usually over-priced and a universal part works just fine for way less money. If you need your oven pronto you will probably need to purchase from a local store (call and get the price). If you have more time, order it on line. (I paid 1/3 the price for mine by buying it online). You might also want to google your Kenmore model + "disassembly" or "diagram" in order to get a picture of the range's components so you will be able to identify and replace your igniter(s).
Posted on Nov 09, 2014
    Filmmaker:
    Uploaded 5 video answers.
  • 37 Answers
You need to verify you have 220 volts supplying your unit
  • Tony
    Tony Nov 11, 2014
    Have you verified 220 volts to the unit?
  • lori guerrero
    120 going to each side of the elements
fridgetech
  • 473 Answers
SOURCE: 970-686133 Bake and Broil Element not working
Typically what happens on on these models, when the bake element breaks, it sends a surge back to the oven control (or clock) and causes it to fail also. Sounds like this is what has happened here. If the overlay (touchpad) is a separate piece, you will need to buy it also. Let me know if you have any questions.
Posted on Feb 25, 2008
  • 184 Answers
SOURCE: Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Posted on Apr 04, 2008
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
docjohn174
  • 943 Answers
SOURCE: Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Posted on Sep 28, 2008
SOURCE: Broil works but Bake does not
change the bake ignitor?
Posted on Nov 05, 2008
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
My kitchenaid range KERC607HBS4 won't bake and broil don't work bake element had burned out so I replaced it but still doesn't heat up
You will need to replace the thermostat that is located under the range top/ Here is the part to order. Thermostat Fix
Apr 16, 2014 | Kitchen Ranges
Bake pre heat isn't working broil and top burners
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 07, 2011 | GE Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
My baking element burned into. can my oven work with just the broil element or does it need both.
I don't know if the broil element will work with the thermostat -- it's usually run full on. You could experiment and see, but the oven will not work correctly with just that element. You're used to baking with heat from the bottom and there is a difference. You might get away with it for pizza and meats -- MAYBE. But, even if it does work with the thermostat, do not try to bake with it unless you plan ahead to throw whatever you're baking away. Cakes, pies, etc. will be ruined with hea from the top. Replace the element -- they're not too expensive and they're easy to change. Just turn the power off first!
Dec 03, 2009 | Frigidaire GLEB30T8A Electric Double Oven
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Dec 09, 2008 | Frigidaire PLES389D Electric Kitchen Range
Kitchen Ranges Logo
135 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
