My driver for Canon i550 is called CNMDR49.DLL its version being 8.04 . My COMPAQ Presario 7EL140 computer turns under Windows XP Pro . The test page sometimes gives the windows logo in color, at other times only black and white. The first two lines of the test page are correct but the rest is hazy. My ink cartridges are new and full. It could be due to clogging of the heads or the ducts, but I tried to clean them several times both with the associated software and also with a clean damp cloth.
What I would like to know is the following:
---Is the incrustation of the heads or the ducts such that I need to throw the i550 away,
-- Is it due to a recent Windows update which requires a newer driver than my CNMDR49.DLL version 8.04 ? Thank you in advance. ==Pertev==
PertevApaydin@compuserve.com
This one...
I had 3 Canon i550 and i560 printer, unfortunately if you use non original inks and leave the print head with no ink cartridge for some hours the ink can dry inside the print head = dead.
I have try several methods of cleaning print head and waste a lot of time on this, finally here some suggestions:
- use pure alchool (at least 90 °) to clean the print head, you can also use clear water but after you had to rinse with alchool because alchool removes the left water that can cause shortcircuit when you power on the print head.
- the electrical connections of the print head (brown ribbon with integrated circuit path) are very fragile if you decide to unmount the print head removing the 2 phlilips screws you must be VERY careful
- for black ,one safe trick is to remove the round (8 mm) glued upper metal sheet filter on the upper part of the print head where the ink cartridge sets. Once removed you can use a syringe needle filled with alchool to remove the dry ink and spray alchool into the small duct hole to remove all the bad dry ink. Be patien it will take some time. You can also leave the syringe filled wyth alchool and without the syringe piston for a night inside the duct hole.
Take a look to the service manual also for other inspirations:
http://rapidshare.com/files/91114670/Canon_i550_i850_i950_Service_Manual.pdf.html
Posted on Feb 12, 2008
Nov 12, 2010 | Office Equipment & Supplies
Jan 02, 2010 | Canon i9950 InkJet Printer
Jul 08, 2009 | Canon BubbleJet i550 InkJet Printer
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
May 13, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Mar 03, 2009 | Canon i860 InkJet Photo Printer
Jan 03, 2009 | Canon BubbleJet i550 InkJet Printer
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Jun 19, 2008 | HP Compaq Presario V2000 Notebook
Feb 17, 2008 | Canon BubbleJet i550 InkJet Printer
622 people viewed this question
