Question about Hitachi P50H401 50 in. Plasma HDTV
I have a hitachi p50h401 tv. when using the hdmi input i do not get sound out of the rca audio outputs. how can i get sound out the rca outputs
    Sergeant:
    Champion:
  • 324 Answers
Check the manual. I doubt that the rca audio is for output. More than likely it's the audio input when using composite video.
i have a hitachi p50h401 tv. when using the hdmi i - 41760e19-ce5c-4e34-8c92-b2bca3f75e4f.png
Posted on Nov 09, 2014
Testimonial: "the rca jacks are marked audio output"
  • Ray Savellano
    Ray Savellano Nov 13, 2014
    From the manual: • S-VIDEO monitor output may be used for recording only when the input is of S-VIDEO type. So HDMI in will not provide audio out on the rca jacks. You will need to use the digital audio out.
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
Fujitsu
  • 29 Answers
SOURCE: Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Posted on Nov 28, 2008
  • 8457 Answers
SOURCE: my hitachi P50H401 not turn on, just the blue
Ur power supply it dead.must replaced.
Posted on Nov 10, 2009
Testimonial: "thanks a lot but I need the diagram for it or who can do it."
SOURCE: Problem with Hitachi P50H401 Plasma TV - Will not
I have the same model, P50H401 and it developed the same problem two days ago. This set is 2 1/2 years old in service, being purchased in December 2007. The original manufacture date was October 2007.
The set was turned on and operating at the time and then promptly shut down by itself. The front blue LED power indicator began flashing four times in a loop or cycle.
The flashing LED sequence in this instance points to a problem with one of the following boards: PSU, X-Sus, Y-Sus or SDRs (there are two SDR boards, SDR-U and SDR-D, both are connected off of the Y-Sus board on the left hand side of the frame when rear facing). The set shuts down to prevent further damage to other boards or components.
I could power cycle the set but it would shut down after after a few seconds. Power LED would stay solid, I could hear the PS relays switching, and audio would output through the speakers. Then as the screen was just about to illuminate, the entire set would just shutdown. The blue LED would again go into the 4X flashing sequence.
I could not visually detect any signs of severe component damage on the main PS board. The two large electrolytic capacitors which have been mentioned as problematic in other threads seems fine. The where slightly raised on the top surface, but not blistered or completely blown open.
The only indication of component damage that I could detect visually was on one of the small surface mounted ICs on the SDR-U board.
Through reading other posts on this site, I learned that I was able to remove the suspect SDR-U board and then re-power the set. Doing this proved that the PS, X and Y Sus, and the SDR-D boards where o.k. The PS held, and the lower half of the screen illuminated. (I would only do this for as brief a period as required to determine if the the other boards would function and the screen would illuminate. Do not pro-long operation in this state so as to not cause further damage.)
It was somewhat difficult to locate the correct SDR-U board. My local service rep did not have one in stock, and the Canadian parts distributor was also out of stock. They estimated 10 - 14 business days to order one up from the U.S.A. (Hitachi closed their consumer electronics division in Canada back in 2009.)
By chance, I checked with another service rep in an adjacent town. He had a board for the P55. We did a visual comparison on the two boards and determined that it would be compatable.
The easy part was removing the defective SDR-U board and installing the replacement. The hard part was re-alinging the three ribbon tabs into the respective connectors on the SDR board. Be careful with these ribbons. The other end of each is fused to the plasma panel screen, so if you damage them, your screen is rendered useless.
I initially had the same problems as others have posted with having black or gray lines on the screen when the SDR-U was replaced. After gently adjusting the position of the ribbons as they are seated in the connectors, the lines disappeared. This was a slow and frustrating procedure, but it worked, Be patient.
Posted on Jul 03, 2010
  • 33 Answers
SOURCE: my hitachi P50H401 will not turn on. No sound no
check your sdr boards. you can test them with a multi meter. they are known for going bad. what happens is the two caps by the output go bad on the power supply and they make the sdr boards burn out. you can replace the two caps and save lots of money. then please check out this web page http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
This web page has info about repairing these. The 4 flashing lights maybe the x sus or the y sus but it's still a good idea to check the sdr boards since its a common failer. I had one tv with a bad sdr board flash 3 time and another set it was flashing 4 times.
Posted on Feb 22, 2011
How to work the hdmi
how do you set up the HDMI input on a hitachi tv model #51F59A ...
https://answers.yahoo.com/question/index?qid...
Jan 8, 2010 - i tried to hook up an HDMI devise but i cant set it on input HDMI it ... My TV has HDMI, Component and AV inputs, which one should i use for my ...
HDMI not working - Hitachi 50VS69A - AVS Forum ' Home Theater ...
www.avsforum.com/.../948284-hdmi-not-working-hitachi-50vs69a.html
Dec 1, 2007 - 7 posts - ‎2 authors
I have a Hitachi 50VS69A 50 RP LCD HDTV connected to a Dish Network receiver that the HDMI input is not working on. I have been using the ... Hitachi P50H401 - all HDMI ports are dead - HELP!
Oct 2, 2008
Hitachi 51/57/65F59A CRT RPTV Tweaks Thread
Jan 19, 2007
More results from www.avsforum.com
Dec 27, 2015 | Hitachi CLE-960 Remote Control HL02121
Connect tv to surround sound system
Connect a RCA cable from the TV Audio output (red/white)
to the surround sound Audio Input (red White)
If your TV has a "HDMI OUT" and your Surround System has a
"HDMI Input" Then use a HDMI cable instead.
You will need to set the source on your Surround System to
the audio source you use on the surround system(input)
On most it will be TV or Auxiliary.
Sep 30, 2014 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
I have a Samsung LCD TV model #LN46B301FUZA, a dish VIP622DVR a pioneer VSX-D307 reciever and a Pioneer DV-414 DVD player that I am trying to get hooked up. The Dish tech hooked up the TV and DVR using a...
I can't find your TV model to have a look at the manual. Normally you'd use a 3-plug RCA cable (Red, White, Yellow) to connect the audio and video outputs of the DVR to an RCA input on the TV. Then, hoping you have RCA OUTPUTS from the TV, you'd use a 2-plug RCA cable to take an Audio OUT from the TV into one of the receiver's Audio inputs (assuming you want to play TV sound through the receiver.
If you have no RCA inputs on the TV, you can get an RCA to HDMI Converter from Amazon for $10-$15 to convert the output of the DVD player from 3-plug RCA to HDMI, then put that into one of the HDMI inputs on the TV. Likewise, if you have only an OPTICAL audio output from the TV you can get a converter for that -- Optical audio to RCA stereo -- and put that into your receiver as an input.
Jan 20, 2018 | Pioneer Computers & Internet
I tried hooking up my laptop to my 37lh20 tv. I connected the avi to the pc input and an audio cable fro the headset jack on the tv. If I put the tv input on rgb pc I get the picture but no sound and if...
Unless you hook HDMI to HDMI, you won't carry sound across the HDMI cable. If you're using a VGA to HDMI converter, you'll get the picture but no sound.
I have a feeling the headset jack on the TV is an output rather than an input. Most TVs accept HDMI, RCA, or a digital audio input (either coaxial or optical). Unless you have a S/PDIF optical output from your laptop (and you obviously don't have an HDMI output), then your only other choice is likely to get a cable that splits a 1/8" headset type connector into two RCA plugs that you'll plug into an AUDIO IN input on your TV.
Jul 14, 2011 | LG 37LH20 37 in. LCD HDTV
I have a hitachi p50h401 and sound went out. someone said update software how do you do that? Thank You
well if the sound went out it may have only effected 1 output source, What type source are you using, HDMI, RCA, Composite, DVI, VGA with mini adapter? If for example the HDMI, port you are using has simply lost sound to that port, HDMI carries both sound and video so simply moving to HDMI 2 or even 3 may solve this issue. Also i would suspect the cable you are using, HDMI cables are often defective. If you are using coax thru your cable company i would also change that coax from your tv to the hd box.
May 28, 2011 | Hitachi P50H401 50 in. Plasma HDTV
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
Connected laptop to tv, but sound only come from laptop. How can I make the sound come out from tv?
If your laptop has a HDMI output, and your TV has a HDMI input, then use a HDMI-to-HDMI cable, which carries both "audio" and "video" signals.
Otherwise, you need a cable from the "headphone" output from your PC into the "RCA" stereo-audio inputs into your TV.
Dec 20, 2010 | HP Pavilion dv6-1030us Notebook
This may be an impossible problem to solve..we just got a Hitachi 51m200 rear projection tv. it does not have an hdmi slot although the tv says it is dvi-hdtv and our cable box is hdmi output. so if i get...
It isn't impossible at all. You may need a sound bar if you don't already have a Bose surround sound system or a boom box or something else you can use without purchasing anything. On the hdmi/dvi televisions and cable boxes of the recent past there would always be an accompanying white and red composite/RCA slot (output on the cable box, input on the television) to accommodate this. You would simply connect the hdmi to dvi cable from the television to the cable box and then the red and white audio cable. If your television and cable box does not have the red and white composite/RCA audio input and output you will need to connect the cable box to an external audio source. How to do it and what to connect it to depends on what audio output that is on the cable box (usually is on the back of it). You might need a fiber optic cable and a sound bar with a digital audio input if you have a newer cable box.
Sep 28, 2010 | Televison & Video
Hitachi P50H401 50 in. Plasma HDTV Logo
150 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
