Thank you for your post, Jeff Duvall!
I see that your Frigidaire washer is displaying an error code of "18h". However, it appears "18h" is an invalid error code. In order to clear any false error codes, let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for approximately ten minutes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "18h". I look forward to assisting you. -Matt
Hello friend, thank you for your post!
The error code "E10" stands for fill time too long, which could be an issue within your pressure sensor or control panel. I would recommend performing a reset on your appliance you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes. If that does not help correct the issue I would seek assistance from a professional to come and properly diagnose your washer. -Matt
Hello & Welcome to FixYa
LOC error code is displayed when the control panel
is locked, to unlock it press the OPTION & SELECT button and hold them for
20 seconds. This should reset the control, if it does not then replacing the
control is recommended repair. Please get back to me if you have any other
questions.
Kevin
