Question about Dryers
How to replace door switch on bosch nexxt 500 dryer
hunter19_46m
  • 7482 Answers
SOURCE: The dryer (Bosch Nexxt 500) makes a loud grinding
The noise could be your drum rollers need lubricant or replacement.
When the drum rollers get flat spots on them they will make a bumping/thumping type of noise.
The grinding noise sounds to me like the drum rollers are in need of lubrication.
Posted on Sep 26, 2009
SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
Posted on Dec 28, 2009
heatman101
  • 43501 Answers
SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 28, 2010
Ranglo
  • 1194 Answers
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.
Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Jun 27, 2010
SOURCE: my bosch nexxt 500 series electric dryer is not
We had the same problem. Cleaned out lint filter and still no heat. We took off the back (lots of screws and had to take top off to get back off). If you are looking at back - at the bottom left there was a red reset button and it clicked when we pressed it (when we pressed it again there was no click). Worked fine after. This solution came from internet. My brother-in-law changed setting to "extra dry"- we usually just used 20/40/60 setting. I think it overheated.
Posted on Oct 04, 2010
Need to replace the foam strip that seals the front door on my Bosch 500 Nexxt series electric dryer....do I do this from the front?
Most likely yes. Get a good adhesive for it though and make sure it is dry before you close the door and before you use it.
Aug 12, 2013 | Bosch Nexxt 500 Dryer
Bosch nexxt 500 elec dryer has no heat to it
There is a switch located on the duct from the heating element. Which you are not able to reset, you have to replace it if it's defective. Do a continuity test on it and if there is no continuity then the switch has to be replaced.
Jan 04, 2012 | Bosch Nexxt 500 Dryer
I NEED SERVICE MANUAL FOR BOSCH NEXXT 500 GAS DRYER
Hi.
I am sorry but unfortunately I could not find the manual for Nexxt 500 gas dryer in my database. The full model number may help me to find the file more than the model name.
A manual for Bosch gas dryer is available in this forum. Subscription to the forum is free: http://applianceguru.com/view_topic.php?id=21241&forum_id=19
When you ask for the manual always include the full model number(e.g.WTMC332SUS ). There are different Nexxt 500 models.
Regards.
G.
Nov 24, 2011 | Bosch Nexxt 500 Dryer
MY BOSCH NEXXT 500 ELECTRIC DRYER IS RUNNING ON 20 MIN AIR DRY BUT WITH NO HEAT. SOMETIMES BY SLOWLY MOVING THE DIAL WILL ALLOW THE HEAT TO RUN FOR A FEW MINUTES. THEN LINT SENSOR GOES ON. HAVE CLEANED...
Did you check this FIXYA LINK below? Appears to have lot's of answers!
Also I WATCHED the YOUTUBE video I recommended and NOTICED his DRIVE BELT is WAY too loose! Methinks THAT is why his dryer has problems!
Be SURE your belt is not to aged because they can STRETCH and then TRIP the "RESET SWITCH" he's talking about. Note the way his PULLEY shakes so violently... AND the action of the belt itself...
20 Most Recent Bosch Nexxt 500 Dryer Questions Answers
Here is another Link!
Bosch Dryer Won Heat 3 min FIX
And yet another!
(DON'T waste your time with the FOUR oval Links to the right! )
Dec 22, 2017 | Bosch Nexxt WTMC 6300 Electric Dryer
heatman101
Apr 27, 2010 | Bosch Nexxt 500 Plus Dryer
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Is it possible to reverse the doors on a Bosch Nexxt 500 series dryer? If yes, does it require a kit from Bosch?
yes ,it is possible,you don't require a kit from bosch,however,you will need to disassemble the machine.if you are not confident,get someone who is.
Oct 16, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Dryers Logo
57 people viewed this question
Top Dryers Experts
