Question about Cameras
Why do I keep getting the Memory Card Full message in any setting other than Intelligent Auto? The camera is a Panasonic Lumix DMC-TZ10, and it works fine using the built in memory. I have reformatted
Why do I keep getting the Memory Card Full message in any setting other than Intelligent Auto? The camera is a Panasonic Lumix DMC-TZ10, and it works fine using the built in memory. I have reformatted the original card, and then tried replacing it, but without success. Any ideas?
    Habit-Forming:
    New Friend:
  • 8 Answers
Usually, when you SD card is full, when it is small in size like 1GB or less, or it is not inserted into your camera, the you have this kind of message. Reformatting of the memory card of you camera should be done using your camera. the best of all is to erase everything on the card and then check the space available on it. then it will be recognised by the camera as an external memory card.
Posted on Nov 10, 2014
  • 3 Answers
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Posted on May 21, 2008
xscrewdriver
  • 246 Answers
SOURCE: memory card locked
There is a switch on the SD memory card, slide the switch to unlock position before you insert the card into your camera.
More detail, see here How to fix a ‘card locked’ problem
Posted on Jul 02, 2009
Obertelli
  • 3006 Answers
SOURCE: Panasonic Lumix DMC-TZ4 black - memory card locked
Remove the SD card and slide the lock switch on it to the unlocked position. If it's already there then slide it fully to locked and then fully back again.
If this fails then you need to try another SD card to see whether it's a camera fault. If the camera is at fault then there's nothing more you can do other than to return the camera to Panasonic for repair.
Posted on Nov 28, 2009
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
Posted on Feb 12, 2010
SOURCE: I have a : panasonic Lumix DMC-LZ3 Digital Camera
Page 92 of owner's manual for DMC-LZ3 states "Do not use memory card larger than 2GB".
Posted on Sep 24, 2010
Panasonic lumix DMC-TZ10 SOFTWARE
Try the free photo cataloging/editing program Picasa.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use the aforementioned Picasa.
Jan 14, 2013 | Lexerd Panasonic Lumix DMC-ZS7 TZ10...
I have taken out the memory card, how do I download pictures from TZ10 camera, The camera says it's memory is full
If you mean the pictures in the camera's own internal memory, you can't just download them. You need to go into the menu and find "copy" which gives you the option to copy the internal memory contents to a memory card.
Sep 27, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
How do I download from the built in memory on my Lumix TZ10
Go into the menu and find "copy"...you can copy the internal memory to a memory card.
Jan 20, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
My camera doesn't recognize the memory card
The problem may be simpler to solve. Perhaps you never normally change the setting from iA (intelligent auto), but the wheel with settings can get moved by accident. If it goes around one place counter-clockwise, it puts it onto the built-in memory, it seems. I had the same problem, and it frustrated me for months!
Oct 29, 2009 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic lumix dmc fx12 states memory card full, when it is not
Check to make sure the memory card is inserted the right way. Otherwise the camera will only read the memory that came with the camera, which is very small.
Feb 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Pics too dark
look at the sensitivity settings (shutter speed), you may have set it too high (set it to auto). Try turning on intelligent exposure to auto/on. Turn intelligent/auto ISO on. Use iA setting for full automatic ono the dial when shooting. As for the message digital pic will go to memory, then that prob means you don't have a SD memory card installed, or it's not formatted, or set to locked.
give those a try.
Dec 28, 2008 | Panasonic Lumix DMC-TZ5A Digital Camera
Panasonic DMC-TZ3 2GB Memory card says full with very few pics.
I think u have to format your memory card through ur camera setting option..
Dec 17, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Cameras Logo
44 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
