Question about Toys
Electric remote car i charge but only makes noise but does not move. without charger doea not move or make noise.
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Have a hoverround mpv 4,do you charge with the controller on or off,when on i get a buzzing noise loud im thinking you charge when the controller is off need help thank you
Typically you will charge with the controller off, but it is not critical. The buzzing noise may be the fan on the charger, which is normal. Make sure the silver handle of the charger is fully inserted into the controller. If the light on the charger is on, you have kept the charger connected for 8-12 hours and still the batteries will not charge, there may be a problem with the batteries being bad and they need to be replaced.
Jan 15, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
May 29, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
Can't connect charger's cables to battery without sparks
NEVER connect positive to negative. You'll damage your electrical system in the car or fry the charger.
It is best to put the positive on first, and then the negative. Remember, it doesn't always have to be the negative post of the battery, it can be a really good ground on the bare metal of your car.
But sparks just go along with it - don't let them scare you. But I always connect the clamps first, then turn on the charger, with the dial on "off". Then make sure of the 6/12 volt settings, and the amp charge you want to put on. A long slow charge overnight fo 12 volt can be 10 amps. A relatively fast is 50. And then to jump it off, go to the setting.
Make sure the battery being charged is sitting in wood, not concrete. If you have the old fashioned battery with removeble water caps, don't breathe the vapors.
May 28, 2009 | Schumacher & Fast Charge Starter Charger
Will not charge
Three things to check that may help you, One, make sure contacts for the charger & remote are clean, because dust can cause it to get a bad connection. Two, make sure your power cable does not have a short circuit. You can either check it with a meter or try the third with the second step. Third, lay the remote on a flat surface with charger plugged in and move the remote around on the charger to see if certain spots work for you. I hope this helps?
Sep 24, 2008 | Logitech Harmony 890 LCD Remote Control
My Creative Zen 20gb MP player has died after an overnight charge. It will not switch on or show as charging when re-connected to the charger. Doeas this indicate a new battery is needed or another...
leave your player for about a day or so.. then try reconnecting your charger.. or go to creative.com and download thier Automated Firmware Update for MP3 Players...
Sep 22, 2008 | Audio Players & Recorders
Car charger lights up but phone does not take charge
try charging your fon in your house outlet. if it works then your car charger is defective. if still your fon wont charge in your house then your fon has a prob in its charging section.
Oct 08, 2007 | Motorola Mobility RAZR V3
Toys Logo
333 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
