Press each alarm button until the light for its sound (buss or radio) goes out.Press each alarm button until the light for its sound (buss or radio) goes out.
You can't post conmments that contain an email address.
Alarm
Your mobile phone has a built-in alarm clock
with a snooze feature. You can set up to five
separate alarms and choose whether or not
the alarm should repeat.
Setting an Alarm
1. From the main menu, select Alarm.
2. To edit the alarm, press the () key. The
following options display:
• Time: Set the specified time for this
alarm.
• Repeat: Select Once (default)/Every day/
Days or customize as preferred.
• Snooze: The alarm will repeat at regular
intervals.
I just had the same prblem. Reconnect your alarm first of all. You need to use your key bob "remote" to deactivate the alarm before starting. It is a feature "good one" i might add that should someone try to steal it the jeep will not start until u deactivate it w theke bob.
The ENv3 alarm clock feature is a glitch in the phone that many users have trouble with. To troubleshoot it, set another alarm and choose another ringtone for the alarm sound. Also make sure you have the V06 firmware.-------------------------------------------------------------------------------- ECU Chip Tuning Tool
O.k. this is a security feature of your alarm the car now essentially thinks that it is being stolen. In order to fix this issue you need to reset the alarm buy reconnecting the battery and using your electronic alarm sensor if you have one (if this doesn't work get new battery for alarm sensor)
Press and hold top left button. hour will flash. use bottom right button to change hour. press top right to change to minutes. use bottom right button to change minutes.
what wont start the car alarm or the car? if its the car you need to shut the door. unplug your key turn the alarm back and if you havfe remote start turn it on then shut off remote start and disable the alarm should reboot the alarm system. if not unplug the battery for about a minute it will reset the alarms disable car start feature
I haven't been able to find instructions for your watch but since most watches operate in a similar manner try the following:- (I assume that your watch had an lcd screen.)
Press the mode button until you reach the alarm setting feature, "AL"? there may be one feature that is specifically for hour repeat "HR"? use one of the other buttons to turn it from "ON" to "OFF".
Press the mode button to return to normal operation.
There is a security feature that will allow to go for a short distance but will stop. It is basically the same as the alarm, when you lock your doors, and then shut the door as you exit, there is a red security light that will blink in the dash. If you manually unlock and open any other door besides the driver door, the alarm will go off. To disable the alarm you have to cycle the key in the driver door. The same goes for the security feature. Cycling the key in the driver door lock manually, should disable the security feature until the doors are locked again. There may be a problem with the remote if you use it instead of you key to unlock your door.
It depends on the model you have. Look on the door panel and look for the control button that shuts off the alarm. Press and hold the button 5 to 10 seconds and that should shut it off. If you don't have that feature, then there's nothing to disable the alarm.
