Question about HP LaserJet 600 M602DN Laser Printer - M
<!-- from fixya rte -->Fuser error printer 50.92.11 - HP LaserJet 600 M602DN Laser Printer - M
  • HP Master
  • 1,915 Answers
This indicates low fuser temperature. Likely the fuser has failed. Power off, reseat the fuser and then start again, if error repeats replace the fuser. Be sure to upgrade the firmware on the printer to the current revision as HP has made some adjustments to the DC controller on this printer to extend fuser life.
Posted on Nov 09, 2014
SVC F5 error
I think the F5 error is a fuser failure error. Check that the fuser is seated correctly in the printer.
If the error does not come up all the time perhaps you can check the fuser is getting hot.
If available perhaps try substituting the fuser for a replacement known good fuser to fully identify the fuser as the cause of the error
Nov 10, 2013 | TallyGenicom 8008 Laser Printer
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
50.4 fuser error
Some suggestions:
  • Turn the printer off for 20 minutes and allow the fuser to cool (this may resolve high temperature fuser errors).
  • Re-seat the cooled fuser assembly (this may resolve other non-temperature related fuser errors).
  • If the printer is plugged into a power strip or surge protector, plug it directly into a wall socket or different circuit (this may resolve errors caused by an inadequate supply of electricity).
  • Try a different power cord (the current power cord may be damaged).
If still a problem, your fuser is faulty and needs to be replaced (typically not a user-serviceable item) by service. Hope this helps.
Jul 21, 2009 | HP LaserJet 5000 Printer
User error
FUSER ERROR:
. Turn the printer off, wait 10 minutes, and then turn the printer on. 2. If the message persists, reseat the fuser. If that does not work, replace the fuser. To check the fuser, turn the printer off and remove the fuser. Measure the resistance between the fuser connectors. If it is not within the proper range, replace the fuser. If there is not continuity between the fuser connectors neutral and hot with the fuser removed, replace the fuser. If the problem is not related to the fuser, replace the engine controller board.
Mar 27, 2009 | HP Color LaserJet 5550hdn Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet Printer 4700 Fuser Error
Try unplugging the printer for 30 mins. You may still have a defective fuser.
Mar 12, 2009 | HP LaserJet 4700 Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
HP LaserJet 600 M602DN Laser Printer - M Logo
2,965 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
