Question about HP Photosmart R727 Digital Camera
What does it mean when a blue light comes on when you try to turn the camera on?
I tried charging the battery, taking out the memory card and plugging it in to my computer and nothing worked. I use this camera a lot and it has so many pictures and videos on it can someone please help me.
  • HP Master
  • 5,530 Answers
What is the question? The camera won't turn on? Is it the blue light? Or do you want to know how to transfer the photos from card to PC?
Posted on Nov 09, 2014
Testimonial: "The blue light comes on when i press the on button."
  •  Mikey
    Mikey Nov 09, 2014
    Where is the blue light showing? I take it that the camera does not power up when the blue light is on?
  •  Mikey
    Mikey Nov 09, 2014
    Reset the camera!
SOURCE: Memory card problem
I had the exact same problem, and i had no luck finding a solution, so i was messing around with it, and i figured out what the issue was. Go to Menu and then to the SETUP option. When you scroll down there should be a USB option. Change it from Digital Camera to Disk Drive, and your computer/camera will register that it has a card in it!
Posted on Jun 01, 2007
SparkGap
  • 363 Answers
SOURCE: memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Posted on Oct 22, 2007
SOURCE: HP photosmart R707 camera does not turn on and charge
I Recomend you to charge your camera before it reaches the lowest level of charge displayed in the LCD Screen This might help the camera to turn on again after long usage but this is something you must take in consideration before it gets ruin but if it is already ruined and you have good luck you might be able to turn it on again and then you shall follow my advise.
Posted on Jan 04, 2008
iwctoys
  • 126 Answers
SOURCE: My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Posted on Jul 03, 2009
daniel_2489
  • 63 Answers
SOURCE: How do you unlock your memory cards for your digital camera?
take a look at the card it should have a switch on the side just slide it and it should be unlocked
Posted on Aug 01, 2009
Msdc blue screen on my camcorder
Try to go thru menu and do a factory reset?
Mar 10, 2014 | Vivitar ViviCam 8025 Digital Camera
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I charged the battery and when I put it back in to use the camera, I turned the power on and the lens came out but a blue screen comes up with the following message: D: 5f08 8233 8234 The lens will not go...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 13, 2011 | Olympus Stylus 760 Digital Camera
I was taking photos and evertime i took a photo i turned it off,(i was on a plane) and then went to turn it on again, and it opened then lens opener (two black things) and then beeps 2 times and turns...
Jan 20, 2011 | Samsung WB550 Digital Camera
Kodak camera C653. Camera will not come come on after green light blinks.then the red light blinks and the camera goes off Batteries is not the problem
Jan 17, 2011 | Kodak EasyShare C330 Digital Camera
My camera cant charge if I put it on the light it dosen't CHARGE EVEN IF I PUT MY USB CORD WHAT SHOLD I DO?
Please note that the camera will only charge from the computer if the camera is turned off. Also try a different USB plug. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare M863 Digital Camera
Ok so my camera turns on the light is on so its charging but when the light goes off it doesnt turn on. what does that mean
I'm not sure exactly what it means, but here are a few steps to solve the issue. 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak EasyShare M863 Digital Camera
No flashing blue light when charging. Lens will not return into
Here are the steps:
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair or possible alternative a new cable.
Contact KODAK:
Nov 28, 2009 | Kodak EasyShare M1033 Digital Camera
My camera shuts off immediately after turning it on, and the battery is fully charged. what's the problem?
Take off the battery and the memory card
Try to wipe the metal contacts on battery with a cloth
Try to put back on to the camera with out the memory card
Try to turn it on
If the camera still have the problem
Try to take the battery out
Try to plug the charger directly on to the wall outlet then plug it in the camera with out the battery
Try to turn the camera on
If the camera has the same issue
Call the manufacturer
Aug 11, 2009 | Kodak EasyShare M1033 Digital Camera
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
HP Photosmart R727 Digital Camera Logo
53 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
