Question about Health & Beauty
My tga 4s breeze mobility scooter keeps jerking and slowing down nearly to a stop when I'm out and about I live in country me and my small dog go out on it every day. But I am scared to use it now in case I get stranded. It has done over 1000 miles and is still like new I love it I was bed bound before so I need it fixed please help.
  • Patricia Fogarty
    Patricia Fogarty Nov 11, 2014
    Got to sorted it was throttle pot needed replacing working like a treat now
    Sergeant:
  • 313 Answers
Without seeing it, I would say it could be the Wig-Wag. This is the lever control you press to go forwards or backwards. It could be the potentiometer inside it breaking down. Also check all electrical connections are tight as this can give you similar problems.
Posted on Nov 13, 2014
  • Patricia fogarty
    Patricia fogarty Nov 14, 2014
    sorted many thanks it was throttle pot..
  • 175 Answers
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
Posted on Jul 09, 2009
SOURCE: mobilty scooter fault
i have a shoprider mobility scooter has soon has i turn on it goes about 5 yards and stops and the alarm comes on i think it has something to do with the brake system could anyone advise me on what it could be thanks
Posted on Sep 21, 2009
gewiz
  • 1271 Answers
SOURCE: Mayfair freerider mobility scooter - keeps losing
ok, sounds like the speed pot,
Can you move the throttle lever up and down, try going along at a constant speed (losing power ?) then move the lever up & down ?
does it improve response ? if so replace the speed pot.
Regards
GeWiz.
Posted on Oct 18, 2009
SOURCE: we have lost the instruction manual for a TGA
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Posted on Jul 19, 2010
ZJLimited
  • 17970 Answers
SOURCE: my TGA eclipse mobility scooter
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
E: info@scooters-mobility.co.uk
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
My mobility scooter keeps slowing down & nearly stops
Sandra,
There are many possible answers, we should narrow down the problem 1st. Make and Model of the scooter makes it easier to figure out your difficulties. Your brake maybe getting hung up and cause this if someone can check if the brake is getting hot when you slow down. That would mean your brake is the problem. If your batteries are loosing power and causing you to slow down that the batteries could be the issue. try my app to help you narrow down the problem. Scooter Doctor App
Jan 24, 2016 | Health & Beauty
Instruction manual for tga 4s breeze mobility scooter can any one help please
Please let me have your email address and I'll send the manual to you. Thanks Dave
Nov 09, 2014 | Health & Beauty
My 4s tga breeze keeps slowing down when I use it any ideas . Please help
hi, okay what happens to the battery indicator when this happens ?
Some points to note : the brake could be coming back on , check the brake by carefully touching it after use , take care because they can get very hot..if's it hot ,,, then it's not releasing fully or coming back on due to a brake issue, controller issue or simply a bad connection..
1. Battery & the charger.. Batteries may be fully charged however that does not mean they able to contain the load you place on them .
2. Brake...
3. a worn throttle pot... (WigWag, the go forward lever is attached to one )
At Worse a controller fault.
I offer a free controller test service..
Regards
Rob
www.gewizrepairs.co.uk
I have got a tga breeze mobility scooter. I charged the batteries as it was not used for a while the display showed up grey put in the key. The indicators & lights etc didn't work but the scooter would...
If the scooter functions OK backwards & forwards and drives the distance you require, then i would hazard a guess at the PCB in the tiller head, paired with BDI (Battery Display Indicator).
Batteries on the Breeze are most likely 70-100ah, and ideally must be kept charged, either after use or at least once per week if you are not using it. Failing to do so will end up costing a lot of money :-)
Sep 24, 2013 | Health & Beauty
Very slow go go scooter
hi, Sorry but those scooters are not stable at higher speeds,
the controller and battery fitted to those scooters cannot be made to give more power hence more speed, there is a number of reasons, the motor draws power from the controller and the controller gets what it requires from the battery, if you put on higher amps batteries , the scooter will go further not faster,
you would need to upgrade the motor to make it go faster, now the controllers are norrmally overrated so it could handle the extra power required, I would say it's impossible to upgrade the motor.
So another mobility scooter would be required,.
Don't get me wrong, there are lite scooters that go 8mph , I think TGA do one.
Regards
GeWiz.
Jan 16, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Mobilty scooter fault
Mar 28, 2009 | Health & Beauty
Health & Beauty Logo
196 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
