Question about Electrical Supplies
I have an HP6700LN,generator, i left it on ,and it went off when the fuel got empty,i just refilled it,buy when i turn it on,even though it powers on , im not able to get electricity into my home ? This is about the 3rd time ,pls can i get any expert advice ?
    Champion:
  • 216 Answers
RESET CIRCET BRAKER.
Posted on Nov 10, 2014
4 Suggested Answers
CarlGehrke
  • 169 Answers
SOURCE: I have a North Star Model 5500 belt driven generator. I am using
Yes it is very possible that you blew 1 or more diodes in the rotor when you overrevved the generator. You also likely shorted the MOV devices that go across the diodes as well. What happened is that the over speed of the rotor caused it to make a much higher voltage than it was designed for and something had to give. I'd suggest that you also look at the capacitor that connects to the stator windings (it's a little like a voltage regulator), you've probably exceeded its voltage rating.
This is pretty much why there are governor mechanisms on generators, much more than 20% or so overspeed makes nasty things happen.
Carl
Posted on Feb 22, 2009
  • 52 Answers
SOURCE: lost electric power to fuel pump on Onan Generator
there should be a fuse at the housing by the start/stop switch. if deisel then take the 10mm screw out of the coolant cap cover and check those fuses. verify power after. good luck.
Posted on Aug 30, 2009
quatlew
  • 139 Answers
SOURCE: hi! there anybody help my power generator won't
Take the spark plug out, connect it back to the wire, and rest it so it is touching metal, Pull the cord and see if you see a spark. If you see a spark that means you are not getting gas. Put a few drops in the hole and replace the spark plug. Pull the cord with the choke off a couple of times and it should fire up briefly. If this is the case you will have to clean out the bowl and gas supply lines.
Posted on Mar 15, 2010
Testimonial: "thx again master it works... 4 drops of gas and even change the spark to a new one and clean the gas valve thx..."
I have a vw caddy 2006 panel van. When the fuel level reaches 1/4 full it jerks when I make left turns and it even cuts off when that left turn is on a steep. Please help
first thought is that the fuel gauge is 1/4 off and the tank is empty enough to allow the fuel to run from the pump pickup
refill when the gauge is 1/2 way between 1/2 and 1/4 and see if the problem persists
Jul 01, 2016 | Volkswagen Caddy Cars & Trucks
Surging
It definately sounds like a fuel problem, lack of fuel..I assume it is running on LP or natural gas. The hose running from the demand regulator goes to the carburetor/mixer. When it gets to the carburetor, there is an adjustable main jet. It is different on different models, but is usually easy to find. There is probably a screw slot in the end of the screw head and a spring under the head. Start it up after locating the screw and open the jet just enough to even out the running. It was factory set, but barometric pressure and altitude and different fuels in different areas will decessitate different settings.
Please let me know if this fixes your problem, Robert
Jun 27, 2013 | Kohler 30RESA 30kW Standby Generator...
My powertrain 6500 model PTG-6500-EXCS won't start. It acts as though it's not getting any fuel. Any ideas?
first check n c do u have any fire at d plug then if so check carb maybe its clog need to be torn down
Mar 24, 2013 | Coleman Powermate Premium Plus 6250W...
I refilled HP 8500 cartridge but printer (Officejet Pro still thinks cartridge is empty. How do I reset ink level?
This model printer may only let you use genuine printer cartridges. If you try to refill these ink cartridges it will not work because the cartridges have an embedded chip in the cartridge that detects the empty cartridge even though it has been refilled.
Mar 03, 2013 | HP Officejet Pro 8500 All-in-one -...
Today while I was driving, The instrument where it telles you how many miles left till empty read 27mi. all of a sudden it started counting down rapidly, within seconds it had went from 27 mi to 4mi left...
Sounds like float in fuel tank is sticking. Usually caused by using cheap gas. Fill it up and add a bottle of STP gas treatment. It might take more then one tankful w/STP to clean it completely. TIP: don't rely on the computer generated "mileage left" especially when that low on fuel, that is only an estimate. And also don't let it get that low on a regular basis because it will damage your fuel pump, fuel is used to cool electric pump in fuel tank and running it that low will shorten the life of your fuel pump.
Feb 23, 2011 | 1999 Ford Expedition
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
I filled in a Dell 924 cartridge and now the printer does not recognize it and does not print
if the cartridge is chipped, it will still be recognised as empty, since the cartridge uses a backwards counter to estimate the amount of left-over ink. there are tools to reset the chip on an ink cartridge to refill it, which you can normally buy in the shop where you bought the refill-kit (if not already included). please note that the cartridge may not warn you again about being empty. when print quality deteriorates, refill. if print quality stays bad (even after a refill), replace the cartridge with a new (original) one.
Jan 18, 2010 | Dell 924 All-in-One InkJet Printer
Refill instructions for lexmark 23 & 24
You will have to buy a new one because the return program cartidges are not reuseable. I read somewhere that the usage is connected to the cartridge, so even if you exchange one with a friend, theirs will not work on yours. Not sure how this works, but I had one and could not figure out how to bypass this feature. Best solution I found was to buy a new printer. It was cheaper than buying new cartridges.
Apr 01, 2009 | Office Equipment & Supplies
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
