How do I remove rear panel, from, Denon USC-m03 hi fi speaker
I am wanting to fit better quality speaker wire to this unit. It was supplied with thin wire, wich simply comes out of speaker rear. Can you help.
    Champion:
  • 216 Answers
YOU CANT SWAP OUT WIRES, WONT MAKE THEM SOUND BETTER, GET BETTER SPEAKERS, WITH THE SAME OME RATING.
Posted on Nov 10, 2014
jack_daniels
  • 304 Answers
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Posted on May 24, 2008
  • 93 Answers
SOURCE: Denon AVR 2807 with Bose Acoustimass 15
Well,i can tell you are not very focus,cause you posted Denon AVR-2807 with Bose AC 15 problem,but under your details,you put down AVR-5807!
First of all,it is so unfortunate that you are NOT able to gain and experience to true ability in sound for this wonderful receiver when you are using a dual tweeters speakers and expect to have good sound separation as a TWO WAY speakers(a tweeter and a midrange-for true high frequency and mid frequency sound separation.)
Secondly,you have defeated the audio configuration of the Denon AVR-2807,since all your speakers are control BY the Bose subwoofer.
Now,i could show you a way to hook this up,and it doesn't matter how you connect them, they are the "bicycle tires" installed with a "Porche"engine if you know what i mean.
If you want a good recommendation for your "beast",i will more than happy to show you the way!
Cheers,
solutiondoct
Posted on Nov 06, 2008
Duncan
  • 218 Answers
SOURCE: Vinyl on Turntable sounds thin and trebley through Denon AVR-1603
You will need an adapter amp which converts the tiny tiny signal from a magnetic phono cartridge up to the line level that you need to feed into your AUX input jacks. They cost about $20 to $30 dollars and can be found at Radio Shack. Unless of course you have a phono input jack on the back of your Denon unit. Good luck.
Posted on Nov 28, 2008
  • 119 Answers
SOURCE: speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Posted on Feb 25, 2009
SOURCE: Require a cable for Hitachi
anyone knows where i can get a cable for a hitachi hi fi midi system ax-m68d model
Posted on Dec 03, 2009
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
How do I remove rear panel on Denon USC-M03
Hi i don't think you have to remove your rear panel to acces inside.
The best way is to remove the speakers by the front side.
Have a nice day
Nov 09, 2014 | Audio Players & Recorders
I have just bought some Tannoy MX1 Speakers to hook up to my AVR-2500 receiver & am wondering what quality/AWG/Impedance rating etc Speaker Wire I should purchase to connect them?
Any speaker wire from an electronic shop will do the job. The bigger the wire core (dia) the better. Talk with the techie for more advice.
May 09, 2013 | Denon AVR-2500 Receiver
I have a 2007 trailblazer. The rear speakers didn't work and some of the head unit lights didn't work. I replaced the headed unit and that didn't fix it. I then replaced both speakers and one...
Put new wireing in going to both back speakers, Factory wireing is verry thin end it breaks with age. Change it over to at least 16 guage speaker wire or 12 guage, Your system will sound a lot better.
Oct 26, 2012 | Cars & Trucks
CAN i purchase speakers for sanyo da 1000
Unless you want the same speakers for cosmetic reasons, you can get a pair of speakers from any Hi-Fi outlet. All you need to know is the max power output of the amp in watts for each channel, and the ohms it puts out. For instance if it says 8ohm 15 watts. You can get a speaker of 8ohms or higher, but not lower. And any speaker above 15 watts.
Actually you can get better quality sound from the speakers as the speakers they often put with these systems are rubbish in terms of hi-fi quality!
PS
Just had a look around the net and the output power in watts is just 8. Couldn't find the ohm rating but most are 8ohm. So any speaker higher than 8 watts will do the job.
Feb 10, 2010 | Sanyo Audio Players & Recorders
Hi i have just fitted my unit into my car but my speaker wiring is a different colour to the one supplied with the unit and i now have no sound, is there an alternative wiring chart with the colours for a...
ok, with the speaker wires in the car you need to get say a 9 volt battery and touch the speaker wires to it and you should hear which speaker wires go to which speaker. The speaker out puts from the unit should be paired up by color all you have to do is figure out which one is left-right-front-rear.
hope this helps
Dec 27, 2008 | Car Audio & Video
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
Denon Receiver AVR-1600
Seeing as you can't put an aerial outside, can you put one in the loft space, if you have one. You could use a standard FM aerial. It wouldn't be as good as mounting it outside, but it would give you better results then a wire.
Jun 20, 2017 | Denon AVR-1600 Receiver
Have a Denon 685 receiver. Purchased a Sony HD tuner (tuner only --$99). Hooked it up to phono input and it worked. After a while protection circuit clicked in. Used integrated tuner in unit. Worked longer...
if you disconnect speaker wire from rear and the problem is solved you will have a real problem in speaker wiring-you must fix it first or disconnect it from receiver and put new wires instead of.
Jul 16, 2008 | Denon Audio Players & Recorders
Right channel not working
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
55 people viewed this question
 Grubhead
Grubhead
