Question about Microwave Ovens
Miele microwave cuts power after 3 seconds of operation then resets itself to correct time. Any ideas?
    New Friend:
    Problem Solver:
  • 7 Answers
It more than likely has a faulty inverter power unit or magnetron.the machine checks the current draw and stops the machine if it thinks it has a fault,hope this helps
Posted on Nov 09, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Posted on Oct 14, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Another Microwave that shuts down after 3 seconds of microwave operation
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. And of course at less than 1 year, this would still be under warranty if you have your sales receipt. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Jan 25, 2007
Master_Tech
  • 770 Answers
SOURCE: microwave turns itself off after a couple of seconds
try to press in on the door after you strat it or down on the door after you start it your interlock switches my be going out
Posted on Jan 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
  • 251 Answers
SOURCE: During cooking, the microwave will work for about
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Posted on Oct 20, 2009
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Oven accidentally operated without any contents and cut out with a smell of burning. Subsequently the oven only runs for approximately 22 seconds before stopping. Any ideas?
    It will require a new magnetron and possibly power supply for it. The magnetron will destroy itself if it has nowhere for the energy to go.
    Feb 14, 2011 | Neff H5642 Convection / Microwave Oven
    My Panasonic Microwave NN-T573SBBPQ cuts out after 3 seconds. what can I do? Or am I better of replacing it?
    This sounds like a magnetron problem, if it gets to hot, there is a special thermal fuse that will open up if it senses abnormal temperature rise from the magnetron and after a cool down period it will reset itself. In rare cases I have known the thermal fuse to become defective and cut out prematurely. My feeling is replace the oven! because by the time you get a appliance repairman in for a sevice call and parts you probably could have bought a new microwave oven.
    Jan 19, 2011 | Panasonic NN-T990SA Microwave Oven
    Microwave cuts off after 3 seconds. Magnatron?
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Microwave Oven Basic Troubleshooting Tips
    http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
    heatman101
    Jan 21, 2010 | GE XL1800 1100 Watts Microwave Oven
    Time count down on microwave oven
    Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
    Aug 25, 2009 | Maytag MMV4205 Microwave Oven
    MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
    might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
    Hope this helped ya
    Cheers
    Johnthetr870
    May 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    Start button intermittent eg press many times (maybe 20) to start
    Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
    Mar 18, 2009 | Miele M625EG Convection Microwave Oven
    Microwave turns itself off after a couple of seconds
    Q - My microwave seems to shut off every once in a while, what might be wrong?
    A - Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
    Q - The fan in my microwave oven is not running will this hurt my microwave?
    A - YES, the fan cools the magnetron and electronics, take the microwave in for service, most fans are not too expensive to replace.
    Q - My microwave blows the fuse inside itself as soon as I push the start button.
    A - Usually a shorted high voltage capacitor...see components section.
    Mar 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    On the face of the microwave that displays the time, we just noticed ////////////along the bottom of the display under the time, we unplugged the microwave and tried to reset it, but no change
    ok if memmory serves me correct
    press the pause clear button with start button at same time
    holding them for 5 seconds the micro should beep then press1 3 5 7 for the reset micro screen its been a while since i serviced a micro but i believe this is correct display reset config for micro
    Jun 02, 2008 | GE Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
