Question about Cabela's Outfitter Series Care-Free Cotton LS Plaid Shirt T, 2 X-L
I have a Mabe stove EM205CNI and need to order oven racks and stove top grates how do I do this? The stove is in Mexico and we live in NM?
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
Where can I go near Polanco to find replacement knobs for my stove?
Actually, I'm not sure where is "Polanco"; guess you are in Mexico City?
Now, to find a site where you may get parts for your Kitchen Range or stove, you should do a google search indicating terms
Parts, Make and Model of your Kitchen Range and Mexico city
If you can't find one near, you might search for an international website, contact them and maybe they can send it to you via some international courier service
Aug 06, 2015 | Kitchen Ranges
I have a mabe gas stove and oven, the outside glass of the oven broke, can the oven be used with just the inside glass? And can I but a replacement outside glass? I live in Santo Domingo, DR.
I have the same problem. I have a maybe gas oven and stove too and the outer glass shattered when we were moving. But we live in Boquete Panama and all these answers only really apply to the US. Any answers.
Nov 19, 2011 | Kitchen Ranges
How to clean grates on kenmore stove
I'm assuming it's for a gas stove... and we're talking about the grates on top. If so, check to see the texture of the part that touches the stove. If it's rough, like cast iron, Use a product like Gas Grate Cleaner. (sells at most stores. Grey, white, black and red container, looks like Comet.) If it's smooth underneath, put it in the dishwasher! Or soak it in the sink. Or, you can use the gas grate cleaner as well.
Inside racks? That Cleaner works awesome on them too.
Sep 06, 2009 | Kenmore Kitchen Ranges
Mabe Stove Parts
replacement glass top for mabe gas stove top
Aug 27, 2009 | Blodgett Kitchen Ranges
High flame on Mabe Gas Stove
The gas supply pressure could be too high and it could be worth checking or if your supply isn't regulated, try fitting a regulator. Maybe the regulator is faulty if you have one.
From memory I think most domestic gas appliances need a supply pressure of 11 inches on a water manometer. Butane pressures can become quite high in warm weather (and drop to zero at freezing point).
Perhaps your new cooker is jetted for natural gas (methane). As that fuel gas has a lower calorific value than butane the jets would probably be bigger.
As a temporary measure you could try using a hotplate for simmering. I have a gadget that is two sheets of perforated steel with an air gap of about half an inch between them. It is nicely made with a useful handle and a loop for hanging and when placed over a low gas flame it allows me to place the glass coffee pot on it with no chance of damage.
Someone local could surely make you such a gadget if you don't find an everyday item that could be used. A car brake drum would lift your simmering pan a few inches and tend to diffuse the heat...
In the laboratory at school there was an asbestos pad to fit over the bunsen burner so flasks could be heated more gently.
I suggest you take a walk and look around with different eyes to see what you can find...
Mar 25, 2017 | Kitchen Ranges
Mabe oven
Hi, well i have researched the mabe oven problem and it turns out that mabe used to make a 110V oven bake element for the ovens made in Mexico. However it appears that they no longer make that model oven and it's parts. Isn't that just golly gee terriffic!I am still searching for an element for it as GE who is also a share holder about 42% worth also has parts that sometimes will fit the Mabe made in Mexico, and not to be left out of the programe Camco is also part of the GE Mabe family so they are also a source to check with, and yes even whirlpool who is nothing to do with any of those other than a competitor sometimes has parts that will fit the Mabe made in Mexico. I'm not saying it will be a perfect fit but if it works, it works, but i'm not recomending you do it to a customers appliance at least not without asking if it's ok.
Feb 18, 2008 | Ovens
Cabela's Outfitter Series Care-Free Cotton LS Plaid Shirt T, 2 X-L Logo
455 people viewed this question
Top Cabela's Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Cabela's Kitchen Range Expert? Answer questions, earn points and help others
