Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
My whirlpool duet steam model # wfw97hexw....it has a sold front cabinet with no access door to clean the filter trap...other machines have an access door near the bottom, mine DOES NOT...so, how do i
My machine is not giving an erro code...it is giving a message saying my drain hose may be clogged or kinked...i would also like to check and clean the drain filter but it is a solid cabinet design and i see no access like other machines have an access panel mine has NO ACESS PANEL so how do i check the drain filter? thanks!
  • 695 Answers
I believe you can accomplish this buy going in from back of machine. Be careful of sharp edges, and unplug power. Remove rear panel screws top, bottom, side and side ,you may need to remove hoses. When your in, the pump is at front, and sits on rubber mounts that slide into their metal housings. You will need to disconnect hoses on each side and push the pump forward or backward you will see this when your in there. Remove pump, unscrew filter, check inside impeller area, and check both hoses each way. You would be surprised what kind of stuff gets through. GOOD LUK FRIEND.
Posted on Nov 18, 2014
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet WFW8300SW leaking water in front
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
My whirpool duet front loader and when my washer get to the last 2 minutes it Flases F. What is this and how do I fix it???
This is a fault code but the F flashes alternately with a number or another character depending on the model of the machine to indicate the fault code number. Since the fault happened at the last two minutes of the cycle, it is likely associated with a drain problem and the fault code is likely F02 or F21 depending on the machine's model.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, you'll find a knob which is the drain filter. Turn the knob counterclockwise to remove the filter and clean it. You may need to lay a towel under the filter to catch residual water before removing it. Manually drain the water, by gravity, from the tub if significant amount of water is still present by placing the end of the drain hose as low as possible into a basin or bucket.
Click on the link below if cleaning the drain filter doesn't solve the problem.
Troubleshooting Error Code F02/F21 on Kenmore Elite and Whirlpool Duet Front Load Washers
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Stops cycle reads suds or F2
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. "Sud" code flashes 4 minutes after the pump is turned on and 4 minutes later "F02" flashes. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter from the pump housing by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
CLEAN PUMP LIGHT COMES ON WHERE IS THE PUMP LOCATED
The pump is located behind front bottom panel on the right side assuming that your machine is a Whirlpool or Kenmore Front-Loader. Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Nov 13, 2010 | Whirlpool Washing Machines
Whirlpool model # GHW9400PL2 solution for the FO2 error indicator
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Nov 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Problem with whirlpool duet
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GWH9100LW1 Frontloader problem
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool awo/d 4305
If you're talking about the drain pump clean out trap, the following link explains how to check it and clean it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
This is the only "filter" on this washing machine. If you need service information, the manufacturer normally places technical information inside the appliance behind the bottom panel under the door. Look inside and there should be a tech sheet taped to the inside of the cabinet walls, or inside the bottom panel. I hope this helps you. Let me know if you require addtional assistance.
Aug 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
150 people viewed this question
Dan Webster
Dan Webster
Sal De
