Question about Pure Digital The Bug DAB Radio
My pure bug radio was fine. yesterday the clock was on but nothing else worked then the clock went out and now nothing. What is wrong and can it be fixed?
Bauhn ADR-6R
Manually tune to a station and hold a knob until it beeps. Do the same for all presets.
Jun 04, 2014 | Pure Digital The Bug DAB Radio
Pure digital radio
Give it a firm thwack with the palm of your hand. I did that to mine and it started working again!
May 14, 2013 | Pure Digital Pure FMDAB Radio
Power windows, A/C, and radio suddenly and simultaneously stopped working on my 99 Plymouth Voyager??????
clock spring in ignition switch not fully ingaged maybe to many keys on your key ring (to heavy) these things can be touchy move key slitely to ingage clock spring.
Jul 07, 2012 | 1999 Plymouth Grand Voyager
I have a Shontek radio controlled clock. It ran fine for a couple of years, then the battery died. I install a new "Durcell" battery and it went through the motions of setting itself but was a...
Your radio should have come with a receiver of some sort for the radio signals to set itself. I had this same issue with my clock when the battery in the receiver died ... try replacing this too. It took me forever to figure out what it was because I had forgotten that it had its own radio receiver ... then once I remembered it existed, I had to find it, but replacing the battery fixed the problem. Hope that helps :-)
May 26, 2011 | Audio Players & Recorders
My Pure Evoke 2 Dab radio has stopped working, it has power but can't get sound stations or anything ...what do i do?
I've got the same problem, from working perfectly to suddenly nothing. "No stations available". Please let me know if you get an answer.
Sep 02, 2010 | Audio Players & Recorders
Trouble code 8001050F
Here’s what’s going on right now: something with the PS3’s internal clock has borked in some pre-slim models. This is not a PSN issue; it has to do with your PS3’s clock. This clock is NOT related to the OS clock. It seems to be a leap year bug. Setting your clock ahead will do nothing. All PS3s around the world were affected at the exact same time.
Does this affect me?
-If you have a Slim PS3, you’re good to go. Continue playing it as normal.
-If you have a “fat” PS3, you may be affected. Some fat PS3s have worked ok, but it seems a good majority have been bugged.
What does this bug mean?
-If affected, your date and time has been set to a random past date. This prevents you from signing into PSN, playing any PSN games, or using any DLC. Your trophies will also not display correctly or be able to sync.
How do I fix it?
-You can’t. Even if you don’t sign into PSN, it won’t help. This is a hardware issue.
So, what do I do?
-Wait 24 hours. Other products that have had similar bugs have corrected themselves after the “bugged” day. On Monday around 6pm central time, all PS3s will automatically correct themselves…maybe.
-If that doesn’t work, we’ll need a firmware update from Sony, which should be a pretty important priority for them right now.
Did I lose my data/themes/etc?
Your save data/games/dlc/themes are fine. They’ll be fixed when the PS3 is fixed. Trophies are uncertain right now, but they’ll be fine if you’ve synced them before the PS3 was bugged. Unsynced trophies are an unknown right now.
If I have a bugged PS3, can I still use it?
It’s probably not a good idea, as I have no idea what will happen to the trophies you earn during the bugged time. Movies/media will work fine.
How do I fix it?
So, what do I do?
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
Fails when trying to read disc, create a game save,trophy or access network. error code 8001050F
How do I fix it?
So, what do I do?
b
Menu button not respondign on a Pure Bug Too
I have just heard back from Pure:
"Unfortunately the item cannot be repaired and has now been discontinued."
I have suggested, since there is no other option available to anyone in our position, that they publsih the scematics.
Sep 05, 2009 | Audio Players & Recorders
Oregon Scientific Radio controlled Thermo Clock RMR382A -
Check the channel mode that you are in. I play with the channel /memory buttons on mine and I finally get it to work. Sometimes it worksfor weeks sometimes just a day. Just glad I can get it to work - thought it was the remote unit but I was wrong.
Sep 03, 2017 | Oregon Scientific RMR-182A Clock Radio
Pure Digital The Bug DAB Radio Logo
55 people viewed this question
Top Pure Digital Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Pure Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
