Question about Whirlpool Ovens
My oven setting keeps changing
The oven setting keeps changing whether its in the grill setting or oven.
  • Whirlpool Master
  • 5,323 Answers
Check the oven temp control thermostat and the oven temp probe with a meter
lastly the control board
Posted on May 18, 2015
Tip
Omega europa oven control settings
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
on Aug 30, 2010 | Ovens
The oven keeps turning its self off
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Mar 06, 2011 | Stoves 720EF Electric Double Oven
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
How do i work the grill?
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Oven no gas
pilote tube could be blocked or pilot orifice set too small. check that the gas pressure is ok
Jun 07, 2010 | Stoves 600GR Gas Single Oven
Teka h e 500 oven wont heat up....
If the fan is working o/k then the oven element is probably faulty, this should be at the rear of the oven behind a removeabkle cover.
Make sure you have the control set to grill , for grilling
Dec 03, 2009 | Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
89 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
