Question about Exercise & Fitness
I have a reebok irun (re - 14301or). It has not been used in nearly 2 years but has been stored safely and had no abuse. The power switch does not come on when I plug it in. I have checked the fuse and power lead and both are working. Any suggestions as to what might be the problem?
reddevil6
  • 1673 Answers
SOURCE: Rainbow D4C power switch replacement
As far as I know, that switch with 6 terminals is still available. But if not, I would wire the 2 for the power head and the 2 motor wires together. Then you would have 4 leads to attach.
Posted on Jan 31, 2008
  • 170 Answers
SOURCE: volvo S60 2005 horns not working
Remove the wire connector from each horn and attach a voltmeter or test light. Have a helper push the horn button while you check for voltage. If there's no power getting to the horns you have to work your way back to the relay checking for shorts. If there is power try holding the horns metal mount against a good ground like an engine bolt or the sub frame. And with wire reconnected have your helper try the horn again. If it sounds then clean rust away from mounting bolt and car (rad support or grill bracket), and look for a loose or broken ground strap to the rad support (from either the battery or engine). If both horns still don't work either they're clogged with snow or dirt (bring them inside to defrost or clean out), or they need to be replaced.
Posted on Feb 07, 2009
  • 143 Answers
SOURCE: My Dyson DC14 Blitz It will not switch on. I have
recommend return to service centre. Electrical safety issue.
Posted on Sep 14, 2009
repairtech99
  • 767 Answers
SOURCE: no power - have checked fuses, power leads and master switch
Well yes, there a problem in the power supply modual.
It does sound like a failing power supply , becuse of the
fact you don't get charge up spark from the plug , wich is normal
affter it's been off /unpluged for 20 min or so .
check the resistance of the plug coming from the set with a volt meter if you have 10 meg ohms or higher,
it's an open circuit and more than likely a 1.50 fuse in the power
supply. If the fuse blows instantly then it's a shorted output transistor or rectifier diode in the switching power supply.
Be a shame to pay 300.00 plus for a stupid fuse.
hope that helps a little . if you have any questions just comment
an i'll respond
Rob
Posted on Oct 04, 2009
  • 140 Answers
SOURCE: no power i have checked the fuse in the plug and
There well my be some internal fuse. If the unit is self powered then the amp may have a problem.
Posted on Dec 12, 2009
My reebok irun treadmill suddenly stops with E3 error code displayed can you help me please.
Try lubricating the belt. My treadmill requires lubricant every now and then. Its not your treadmill but a treadmill is a treadmill. That's what stops the belt from slowing down due to friction. Go to your nearest Gym they may be able to sell you a tube of lubricant. Good Luck
Oct 23, 2016 | Reebok Exercise & Fitness
What is the output voltage output to the rebook Irun 14301
Pull the belt with your feet while voltage applied to motor. A motor brush may be stuck
Jun 08, 2014 | Reebok Exercise & Fitness
Looking for a reebok irun adapter re- 14301
go to www.fitnessrepairparts.comand get itGod bless you
Mar 15, 2013 | Reebok Exercise & Fitness
Irun treadmill not working- blank screen, belt not running but power light on
1) adjust the REED swtich, clean, and tigh the wires connector.
2) After you did the adjustmente RUN the software calibration for diagnose, troubleshooting, and fix it.
see the diagram attached.
Jul 03, 2012 | Reebok treadmill i-run s
After i run a mile or so the reebok irun will cutout how can i solve this problem
Dear Sir:
Please LUBE The lack of this produce enough friction between deck vs deck belt. this cause to shut down the machine.
After you lube RUN the software calibritation for diagnose and troubleshooting.
2) Test the main motor measure the input voltage.if there are the problem is the motor need repair.
3) Test the main board for output for input voltage motor, if there are Not the board is Faulty.
sincerely. God bless you
May 02, 2012 | Reebok Exercise & Fitness
My reebok run won't work although the power is on
Dear Sir:
1) Reset the c. breaker from your outlet home.see if some wire is loose.
2) Do not use extension cord, the drop of voltage is not O.K for to keep running the treadmill.
3) Reset your c.breaker or fuse from your treadmill, is to the side of power button.
4) See internal some wires is loose.
5) Test the input voltage for 115 vac with a VOM., IF THERE ARE MISSING, you have problem with the c.breaker or transformer.
see the block diagram for illustration. sincerely. God bless you.
ernesto cuadra
managua, nicaragua.c.a
Feb 11, 2012 | Reebok Exercise & Fitness
Dc greenmaster gmd 82-05-2b how muchdoes it cost and where to buy? reebok irun treadmill motor does not work , need replacement
i want to purchase dc motor 3 hp continues duty 230 v dc power supply and 4800 rpm form my treadmil. please suggest. i am in chandigarh India.
Apr 25, 2011 | Reebok Exercise & Fitness
How do I turn off my Reebok 8050 ES? I can not figure out how to turn it off when I am not using it.
Plug in the power cord. Next, locate the reset/off circuit breaker on the treadmill frame near the power cord. Switch the circuit breaker to the reset
Apr 20, 2010 | Reebok 8050 ES Treadmill
Exercise & Fitness Logo
53 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
