Question about Car Audio & Video
Can a GM 5602 amp see an 8 ohm load bridged, and if so what wattage will it push
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
The Pioneer GM A5602 can handle down to 4ohms bridged @450W continuous. So not sure of the difference between the GM5602 and the GM (A)5602 but I would bet it would be able to handle an 8 ohm load easily. Probably at about half of the power(225W)...which is still quite a lot depending on what you are planning on pushing.
Posted on Dec 12, 2014
Mitco39
  • 62 Answers
SOURCE: Rockford Fosgate Punch 360.2
If the wires were touching then the amp overworked itself into a early grave..What happends when they touch is the amp goes from seeing a 4 ohm load to seeing a 0 ohm load. You can imagine why this would be bad for a amp...usually the amp should shut off to protect from damage and I would assume that Rockford would. Right now im having a similar problem..I suggest your call rockford and ask to talk to a technical advisor ( the name escapes me) and ask him what he thinks.
Posted on Mar 25, 2007
  • 323 Answers
SOURCE: wiring configuration 800a2
http://mobile.jlaudio.com/support_pages.php?page_id=161
Here are the diagrams for running dual voice 6 ohm sub's.
Posted on Apr 19, 2008
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
etirbynnor
  • 655 Answers
SOURCE: Ccan it be bridged with a 5 ohm subwoofer?
Hello cameron_cran,
The information I found on the amp is that is a 2-channel and is bridgeable. It is stable in bridged mode to 4 ohms. You should be able to bridge a single 4 ohm sub without damage to the amp.
Hope this helps.
Posted on Apr 22, 2009
etirbynnor
  • 655 Answers
SOURCE: rockford fosgate p500-2 overheating
Hello rodnekyl,
If you have that amp inside a box with no airflow for cooling, it will overheat and cut out no matter how you connect it, or what the impedance load you are running. Higher impedance equals less power, less heat. Lower impedance equals more power, more heat.
The amp is only stable to 4ohms in bridged mode, so the 2 SWE-1242 Type E's connected in parallel would be a 2ohm load. Wiring each sub to a separate channel presents a 4ohm load, which is OK.
After getting some airflow to the amp, the next thing I'd consider is a "big three upgrade". It's less expensive than a capacitor, and probably much more effective. And all you need is about 10-12 feet of 2 gauge wire, 6 ring terminals, some tools, and about 1 hour with a cool engine. If the amp still cuts out after cooling it down and getting more current to it with the big three, then consider installing a cap.
Posted on May 11, 2009
How do i wire alpine swr1243d subwoofer
There are a couple different ways you can wire up this speaker as it is a DVC speaker. Duel Voice coil, it has two + post and two - post. A dual 4-ohm voice coil subwoofer with its coils wired in parallel presents a 2-ohm load to your amplifier. Since an amplifier produces more wattage at a lower impedance, the parallel connection ensures you'll get the most output from your amp.
Series wiring lets you configure multiple woofers to one amplifier at an acceptable impedance. Wire both coils in series for an 8-ohm impedance, and then wire two 8-ohm subs together in parallel for 4-ohm total impedance.
You can wire each voice coil to a separate channel of your amplifier, if you prefer not to bridge your amp. Independent wiring is a nice option if you're wiring two DVC subs to a 4-channel amplifier - one voice coil per channel
Depending on what you are hooking it up to i.e. a mono amp or a bridged four channel amp. I can tell you post to wire exactly if I know how you want to hook it up and what ur hooking it up to.
Sep 15, 2014 | Car Audio & Video
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    My kicker still pounds a lil bit but not lie it used to i think i dropped the ohms too much what do you thik the problem is
    It has to do with Ohm rating along with what your power amp specs are. If you are wired to have this dual voice coil speaker for 2 ohms (parallel), then your power amp might not perform, or able to handle the 2 ohm load, and therefore might go into thermal overload/protection. If you are wired to have this dual voice coil speaker for 8 ohms (in series), then your power amp will not put out the wattage it is rated for, or be able to "push" it at all. The higher the ohm load, the less wattage output from amp, especially if the amp is made to work at 2, or 4 ohm load. Check your specs.
    Apr 26, 2010 | Kicker CVR15-4 Car Subwoofer
    I have 2 12'' subs 1300.watts and 2 1200watts amps both bridge to push 2400.00watts do not sound lond enoungh
    impedance mismatch cud be the culprit. make sure ur speakers are the right ohms for ur amp. most amps are designed to operate on a 4 ohms speaker load on bridge mode. some amps are never designed for bridge mode. so if u bridge these amps u will get less output. u have to be very careful when u make the connections. plus when u bridge two amps for 4 ohms load, the total impedance becomes 8 ohms. make sure ur speakers are 8 ohms. few ohms can make big difference on power amps.
    Apr 07, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
    Help with hookup
    I am assuming you are driving a sub-woofer. Run the amp bridged at 4 ohms. So a DVC(dual voice coil) 8 ohm sub with voice coils wired in parallel would give you a 4 ohm load. Just make sure the sub can handle at least 300 Watts Peak.
    Dec 17, 2009 | Pioneer GM-3300T Car Amp
    What do you mean by the subs should have more watts than the amp.and subs mean woofer ? actually i dont know any thing abt this. what is 8 ohm stereo, 8 ohm bridged,4 ohm stereo. etc etc...?
    If your planning on using a stereo system in your car or home you need to follow some rules otherwise your just wasting money. The watts of a speaker means how much power it can handle. The higher the number the more power it can handle, and usually the louder it can get without distorting. If your amp has more power or close to the wattage rating of the speaker you will blow the speaker, it can even get so hot it ignites. The amount of ohms is the electrical resistance the speaker provides. House speakers usually have 8 ohms where car speakers tend to use 4. 8 ohm stereo means your left and your right are separate channels and each speaker has 8 ohms. 8 ohms bridged means you bridge the left and right channel to increase the power output of the amp and you have to use either 1 8 ohm speaker, or 2 4ohm speakers in parallel to prevent damage to the system. Same goes for 4 ohms. If I remember correctly you want your sub(woofer) to have a wattage rating 20% higher than the amp. Remember if the speaker overheats its no good, but most amps if they overheat they just shut off until they cool off, but only if they state they have a thermal overload protection.
    Jul 12, 2009 | Solid Audio Formula Series F2000 2-Channel...
    How to bridge a punch 3001 car amp
    You can't bridge this amp as it is a mono single channel amp. 2 ohms is the lowest load that can be applied for 300WRMS.
    Feb 24, 2009 | Rockford Fosgate Audio Players & Recorders
    What are the correct spaekers for the gm 5100t ?
      CEA-2006 Compliant Amplifier Power Standard:
    • 125 Watts x 2 @ 4 ohms <= 1% THD+N
    • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
    • 75 dBA Signal-to-Noise Ratio
    • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
    • 2 Channels
    • Continuous Power @ 4 Ohm: 125W x 2
    • Continuous Power @ 2 Ohm: 190W x 2
    • Continuous Power Bridged @ 4 Ohm: 380W x 1
    • Frequency Response: 10Hz-50kHz
    • THD (1kHz, 4 Ohm): <0.015%
    • Signal to Noise Ratio: >95dB
    • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
    • Oversized Screw-Type Power/Ground Terminals
    • 2 Channel RCA Inputs
    • Speaker Level Input
    • Hi-Volt Input Level Control (200mV-6.5V)
    • Bass Boost (50Hz, 0/6/12dB)
    • Selectable LPF (80Hz, -12dB/Oct.)
    • Pioneer 1-Year Warranty
    I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
    Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
    Help on 1 amp and 1 alpine srw-124d
    You have dual 4-ohm coils. 2 coils per speaker.using one speaker, if you take and run the postive from one coil and connect it to the negative of the other coil, then take a wire from your bridge channel on your amp and connect the positive to the the remaining positive on the one coil and connect the negative to the remaining negative on the other coil you will create a 8ohm load on the amp in bridged mode.
    now this is the important part. The bigger the load on the amp the greater the wattage output to the speakers. This sucks the wattage out of the amp. Careful not to overload you amp. The setup above is safe for any amp. The following is for 2ohm stable amps only. The lower the ohm value 2, 4, 8 and so on, the greater the load on the amp.
    connect the positive of one coil to the positive of the other. connect the negative of one coil to the other negative of the other coil. then take a wire from your bridge channel on your amp and connect the positive to the the positive on one coil and connect the negative to the negative on the same coil and you will create a 2ohm load on the amp in bridged mode.
    Series = add the two ohm value
    parallel= halve the ohm value
    you can play with series and parallel together using more than one speaker setup.
    Jun 07, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    Wiring my subs to my alpine mrv-1000
    did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
    I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
    and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
    Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
    Car Audio & Video Logo
    75 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
