Remote does not work properll
Remote does not work properly
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 173 Answers
If you don't explain what exactly is going wrong, how can we help you ?
Posted on Nov 09, 2014
I have a Emerson lf320em4a with cracked glass can I take the glass out and would it still work
It is a microwave designed to work as sold ....not with modification. Microwaves can cause cancer I believe. Have the glass replaced , have the machine properl repaired or buy a new one would be my thinking.
see link below for some information
Jun 20, 2015 | Emerson Microwave Ovens
No sound for netix
plz install proper driver or rollback if they works properll in past
Mar 30, 2014 | Computers & Internet
My usb flash disk suddenly stops working properl when i transfer a file...i cannot find it in my computer..but it connects properly.. what will i do..
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Mar 21, 2011 | Computers & Internet
After switching on, windows does not start properl...
Sounds problem with some System device drivers.
First try rebooting the system in safe mode. If it works, hopefully booting in last good known configuration will solve the problem.
To go select "last good known configuration" boot the system and during POST keep pressing F8, this will bring up "Windows Advance option menu".. move down to select "Last good known configuration"
and hit enter. If this doesnt works follow below instructions
If both of the above doesnt work, try repairing your OS, Follow the below instructions
Insert OS boot CD,
Boot your system from CD ROM.
On the window "Welcome to setup" dont go for repair. Hit enter, and next press and then on next window press R to repair.
Hope this helps
May 21, 2010 | Dell Latitude D600 Notebook
It doesn't froth properly
Trial and error solved the problem. The milk island is great but needs REGULAR cleaning. In order to clean properly one has to take apart the milk island and clean all rubber components of the dried milk that can and will accumulate. The most important cleaning taking place in all little holes as they are most likely to clog from the dried milk.
Jan 30, 2010 | Saeco Milk Island Automatic Frother -...
Cant receive faxes
plz check all cables properl there might be damaged one ... then check you fax machine ink ..if none seems to be the problem the get it once serviced it will get back on working
Aug 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Door will not shut properly
Sometimes doors can getted warped. One trick is to tortion the door in the opposite direction by holding the bottom of the door with your leg and twisting the top with your hands. Sometimes you may have to loosen the liner screws under the door seal to make this work. Hope this helps
Jul 29, 2009 | Frigidaire Refrigerators
I lost my scanner icon from taskbar scanner will not work properl
Right click on the taskbar go to properties then click on customize button and select the appropriate icon u want.
May 01, 2009 | Office Equipment & Supplies
Not starting properl doesent seem to engage
Some things to check:
Is your battery fully charged and does it have the proper amount of electrolyte? Use a multi-meter across the battery terminals, you should get around 13v (direct current). Watch the meter as you try to start the scooter, if the voltage drops a lot your battery is probably bad.
Is your starter button working? When you press the button do you hear a click or get any indication it has been pressed? Has there been any damage to the switch area recently?
Is the starter working? Do you hear the starter turning the engine over, or is the starter just spinning? If just spinning and your battery is good, check your starter solenoid.
Jan 02, 2009 | 2006 Derbi GP1 125
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
